Fuzzy cuts
Started by JamieK, June 25, 2021, 09:13:16 AM
JamieK
Hey guys, I'm milling pine 2x4s on the Lucas mill and am getting very fuzzy cuts. I understand that these are rough cut but still, these things look bad. I changed to a new blade withe slightly improved results but after 5 cuts at was back. Im using additives to the water and still fuzzy. Is this just normal for the Lucas or am i missing something.?
Wood-Mizer LT70 full line, BMS250, BMT100, Moffet M5,Nyle L200M, Lucas mill model 7 with slabbing attachment and planer attachment, Logosol PH360, 2017 Ford F450 Platinum
alan gage
Softer wood seems to give fuzzier cuts on my bandsaw.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
WV Sawmiller
   I'm getting the same look on my spruce.
  And I'm using 4 degree DH blades if the hook angle has anything to do with it.
barbender
Spruce always fizzes the drier the wood the worse it does it.
WV Sawmiller
   Mine had not been on the ground but 2 days.
JamieK
Hey guys, thanks for your input. So far the only thing that helped was pulling the blade through the cut faster. When using my LT70 I have absolutely no issues like this when using dish detergent in the water.
maple flats
Re-sharpen the blade and then try more water, those tended to help on my Peterson when I sawed pine. However it was never like the results with hardwoods.
For me I found poplar worse than pine in the fuzz department.
