Got some new help for the operation
Started by Kipper, November 24, 2016, 06:32:14 AM
Kipper
Hey guys, haven't been on in a while, been real busy with work. Pulled the trigger the other day on a newer/used "helper"! We bought a piece of property back in July that I am going to use it to help clear it and I was able to sell my old one to a friend. Really looking forward to experiencing tracks!  Happy Thanksgiving!
LT40HD, Cat Diesel
New Holland L783
Kubota BX23
Metavic 1400XL
2016 Dodge 3500
2007 Dodge 3500 (Dump)
Belsaw 802 Edger
Too many trailers to count and all Stihl Saws!!
Looks like that just for use around the sawmill?  :)
Savannahdan
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
slider
might as well get you a root grapple if you are clearing land.It will come in handy around the mill.
al glenn
Kipper
Slider, I have a tine grapple, not sure if thats the same thing. I use it a lot around the mill moving tree's. I remember when I first got the grapple I don't think I use the forks again for a long time. I am looking at getting a stump grapple now. It's a real narly looking bucket with a grapple on it for digging stumps up. Should be interesting.
LT40HD, Cat Diesel
New Holland L783
Kubota BX23
Metavic 1400XL
2016 Dodge 3500
Belsaw 802 Edger
Bruno of NH
You will like the tracks
My friend has one they work great on soft ground
paul case
Good for you!
When I bought my skid steer, my dad already had a hydraulic post hole digger for it. I since have bought a set of forks, tree shear, hay accumulator,bale spear, and another set of forks for it. I have more tied up in attachments as I do the machine. I use it almost everyday at the mill. Handier than a shirt on a pocket.
PC
pc
ChugiakTinkerer
Congrats!
I'm in need of a helper too and have settled on a compact utility tractor (CUT) or a compact tracked loader (CTL).  Would love to hear your first impressions of working with your new helper.  Is that a T180?
Woodland Mills HM130
ozarkgem
Can't tell the size. Look like one of the bigger ones. My plan is to up grade to a bigger one next yr.
Seavee
Looks good Kipper. That should do the job.  Happy  Thanksgiving
Wood mizer lt50 47hp yanmar Diesel  Sthil MS311, Ms661 MS200T, 029 farm boss  and a New Holland T4  75hp.
Kipper
Thanks guys!
Its a 2010 T630, 74 hp with 23 gpm flow, 2400 hours. I had an older New Holland L783 and recognized the need for tracks and a newer machine so I sold the New Holland to a friend and was able to pick the Bobcat up for a good price.
I also have a Kubota BX23 which is a sub compact tractor with Backhoe. It has a very low lift capacity and is considerably smaller. I looked at larger tractors but you can not beat the lift capacity of a CTL or Skidsteer for the size of the foot print. They are in some cases quite a bit more expensive but I had already accumulated some attachments for it and was used to running one. Not to mention needing to clear off this piece of property it just seemed like the right fit for me.
LT40HD, Cat Diesel
New Holland L783
Kubota BX23
Metavic 1400XL
2016 Dodge 3500
Belsaw 802 Edger
