# 1 saw bench. build
Started by weisyboy, October 10, 2010, 07:34:10 AM
buildthisfixthat
thats the hard part is to get the carrage back and foward at a variable speed ..and what are you making for head blocks ?those are tricky to make because you have to make them to hold a log and also to hold a beam or board ?
shop built bandsaw mill
weisyboy
i wont need head blocks fo now ill jsut work flat top trolly's at first.
im gunna set it all up and see how it cuts be hand pushing the trolley at first. tehn see how it goes,
if it runns really well i might turn it into a candain saw latter on.
got the spindle on and blade mounted so i could put on some packing blocks, will take pics tommorow.
part from that i need to make the outfeed rollers. its almost ready to move out into the padock, and have the track laid.
god bless america god save the queen god defend new zealand and thank christ for Australia
www.weisssawmilling.com.au
http://www.youtube.com/user/weisyboy?feature=mhee
http://www.facebook.com/profile.php?id=100000696669814&sk=photos
weisyboy
got the packing on, so the bench is all ready to go.
got the cradle almost done, jut needs a coupla dogs.
northwoods1
I don't know about anyone else but I am eager to see this project come together and saw some wood 8)
weisyboy
i know i sure am. ;D  i can feel it getting close now.
why are my pics so small?
Yes, why are you making them so small?  Very  hard to see them, and yours didn't use to be small....if I remember right.
weisyboy
Yes you have.  :)
Gone from 600 pixel size down to 80. Don't believe the FF will do that but it is on your end.  :) :)
weisyboy
ill have to have a look i haven't changed anything on my end.
weisyboy
settings on my camera had been changed somehow . all better now.
weisyboy
now its getting exciting.
just cam in for a smoko, will fix the track down this arvo and see will be ready for a test drive. ;D 8) ;D
OFFSITE IMAGES ARE NOT ALLOWED!!!!!!!!!!!!!
tyb525
weisyboy
i heated and hammered out the ends, so they are sharp, a whack with a hammer to jam them into the log and it aint gunna move.
weisyboy
 ;D 8) ;D 8) 8) 8) ;D :) yay, still not finished >:(
fishpharmer
Fresh sawdust, you did great 8) 8) 8).  Your gonna have a lot of sawdust when you finish that big pile of logs.
Dang nifty log dogs you made too.  You know not just anyone can make a sawmill from scratch 8)
Have you worked out the setworks yet?  You could use the old tape measure and bump setworks, but its kinda slow. ;)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
weisyboy
measure and bump will do for now.
weisyboy
thats not all
thats not even half the pine logs, then iv got about twie that amount again of hardwood, but there for the lucas.
anyone know if you can still buy flat canvas belts?
weisyboy
QuoteDang nifty log dogs you made too.  You know not just anyone can make a sawmill from scratch
thanks mate, im not the first and im sure i wont be the last. when you cant afford to buy something then ya just gotta build it.
Meadows Miller
Gday
Another trick you could use mate is to make nicks into the dog rails at the distances from the saw for your cant sizes a couple of flat top carriages i have used i the past had them and it made it quick n easy to get a  accurate 3 sided cant with 3 wing boards out n down to the bench Mate  ;)
Regards Chris
4TH Generation Timbergetter
terrifictimbersllc
pretty amazing I get stumped just figgering how to make some fake peterson water bottles
weisyboy
peterson watter bottles are just a 20l drum, with a tap on the bottom.
paul case
looking good weisy. with that tractor sitting there it kinda reminds me of a belsaw.
that is some kind of a wicked blade though. with the fewer number of teeth ,does it slow down the feed rate?pc
pc
northwoods1
I sure like the simplicity of it. That cant looks nice wonder how much production you could get with something like that? I noticed you have your pine logs stickered that must make them last longer hey?
tyb525
Yeah you can still buy flat belts, at least over here anyways.
weisyboy
gday
the balde is meant for high speed, low hp, and dosen not need retention ever iv got 8 of them different sizes.
it cuts fast even at half the required pto speed,
found a mob that sells flat bets today.
