Granberg mini mill
Started by okie, May 22, 2007, 04:18:50 PM
okie
Has any one on here used the granberg mini mill saw attachment?  If so do you have to drill the bar for this attachment. I have a Beam machine and it works but there is inconsistencies in the cuts. I have heard that the mini mill is much more accurate? I am not milling lumber, but cutting three sides from honey locust logs for building. Any imput is much appreciated.
Striving to create a self sustaining homestead and lifestyle for my family and myself.
Kevin
I've have used one and still do.
It has a tendency to cut on a slight angle sometimes but you can check it with a square before you make a cut and shim it if necessary.
It bolts to the bar not through it.
It's good for cross cutting too.
okie
Thank you Kevin. THe only reason I didnt get one in the first place is that I thought they bolted through the bar. I will order one this week.
