jd540b
Started by AJS1974, May 07, 2012, 09:45:48 PM
AJS1974
looking for the Serial number to order some parts.
AJS1974
Can someone tell me where the serial numbers are located on this machine.  Thanks
grassfed
If no one else knows the JD dealer should be able to tell you over the phone.
Mike
Decked
FWIW..
on my D model..it was under the rear of the cab..on a plate on the frame
AJS1974
Thanks, will look tonight.
doghunter
the 440b's numbers were on the transmission case about 8-10 inches above the frame rails i think on the right side if i remember correctly 540s may be the same
AJS1974
found the serial number.
Tramp Bushler
They should have worked alittle harder at hideing it . Wow
If your not wearing your hard hat when you need it. Well.
danno
Hey AJS, that's a mighty fine lookin' skidder you have there.  ;D
I can see it now, the pic you sent me over the phone.. I had no idea what I was looking at.
Owner of a small sawmill & logging operation.
