Recent
470 Guests, 3 Users
doc henderson, TimW, rabuchanan
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Hey guys my dad is a retired swamp logger now heavy equipment mechanic. He has ran into a problem on a 2009 Tiger Cat Loader. It has no pilot pressure. He said it will run but has no functions. He has changed out the pump to a good used one, changed filters. He has been scratching his head on what could...
Read More
1 Comment
G'day I may be cutting a load of timber for someone for a greenhouse,
Included in the list is 4x4s 13 feet long, these will be cut from stringybark logs, to cut them free of heart and cut the tension out I would need a log 20 inches across, would I be fine to box the heart for them? So I can get them out of smaller logs.Read More
4 Comments
Im new on this forum. Don't trow me rocks plz. I just purchase a John Deere / Timberjack Forwarder 1010D 2005. I do have persistent issue. I would like your help to diagnostic.
At the beginning I had crane speed / control issue. Changed one of the joystick / calibrate / adjusted by the dealer. Now run as new corect speed and all movement works.Read More
1 Comment
I have a Timber Harvester mill and when any of the hydraulic levers (taper, turner, log lift etc) are moved the head creeps toward the front/operators station. It moves maybe 6" or so.The hydraulic fluid level is where it should be and I have changed the filter. Any ideas as to why this is happening?...
Read More
3 Comments
Would appreciate some help with finding the gremlins or whatever.
I have a 2005 WM LT40HDD34 with a factory installed blade lube system.
The problem I have is that when using the blade lube system with the switch in the pulse position sometimes it works the way it is designed too and sometimes it is continuous. Read More
4 Comments
Pages: [1] 2 ... 40
