Gas engine for planer?
Started by Edvantage, January 01, 2021, 02:02:06 PM
Edvantage
I was given a crescent planer 24". Cutter head is square with two blades. Motor on it is massive patented 1903. Tag says 7.5 hp 96 amps 104 volts single phase. Or 48 amps 208v. I can't imagine the start amps. Another friend just dropped off nearly new kohler 16 hp v twin engine.  I'm thinking the gas engine might be the better choice. I plan on running it outside. Is 16 hp enough? Currently need to plane pine but I'm sure I would end up running some maple.
Southside
Square head planers deserve to be in a museum, reduces the odds of them killing someone.
I would not recommend running one.
Edvantage
Is it worth changing the cutterhead? So far it's cost me nothing. Or am I wasting my time?
Andries
Crescent has made some really good equipment, good machining and solid cast iron.
Check out  the OWWM (old woodworking machinery) website for advice and info on the 'how and if'  of changing out the square cutterhead.
Some FF members may jump in with some really specific answers as well, but like SouthSide says; change it up or park it before someone takes a chunk of wood to the gut.
Don't get any of us wrong, I really like old machines.
My 1919 vintage Yates jointer is old iron, and the OWWM group helped me get it into great shape.
LT40G25
Ford 545D loader
Stihl chainsaws
Edvantage
I look at lightweight new planers and the price tag. And than I look at the heavy iron on this crescent and it seems to me it would work with a new cutterhead. My problem is I have spent most of my life making everything from scratch or the hard way because I can ( or I can't afford new) just stopped at a friend's house his yard is full of half repaired old stuff. Can he make it work? Sure he can but at what cost in time and effort. The reason I have the planer and engine is I have helped other people fix there old junk so they give me there old stuff. It's a lifestyle I guess.
mike_belben
Yup, a blessing and a curse.
16 horses will pull a house so on a treadmill i reckon they ought to shave wood just fine too.
Praise The Lord
muggs
Here is a second opinion on not using that planer. I broke my arm on one from a kickback. That motor at 104V comes from around the turn of the century. That was the voltage they used then. ::)
Don P
It can be made to work and that should be enough power, man the amp draw and hp of the old motor sure doesn't sound right. The square head knives are really hitting the wood at a bad angle but they can be back ground to help fix that. Or you can retool it with a round head. They can throw boards but operated within their limitations and being aware they do work.  A friend broke a hand on one, a 1904 we were all glad to see go up the road, the potential is definitely there. I've seen one with anti kickback fingers fitted on it. @Paul_H restored one some years ago.
mike_belben
Sharpened bicycle freewheel sprockets will make a good anti-kickback feed guide.  The ones with the ratchet pawl inside.
Praise The Lord
Edvantage
I have a healthy respect for kickback. Once had a table saw kickback so hard the board hit the end of my thumb splitting the main bone and shoving the tip between the two halves. I had an instant short fat thumb. If I do anything it's going to be a new cutterhead. Just gotta find the time.
mike_belben
I stalled a good old 3hp or so delta rockwell table saw with a sheet of plywood and a pair of testicles once.
:o
Praise The Lord
Southside
Saw Stop Mike - Saw Stop, won't hurt nearly as badly as that did.   :D
Paul_H
DonP tagged me so I thought I'd weigh in with a couple of links.
I bought a Heaps Waterous 6 x 24 " 4 sided planer  built in 1940 with square heads. We ran a lot of on and two inch T&G flooring through it but it was limited in speed to get a nice finish because we only had two knives per head. It was slow to change thickness or profile but width was no too bad. It has an infeed table so kickback was never an issue although without it it could have potential for injury.
It is powered by a Chevy 350 with automatic trans and the driveshaft was direct to the input shaft and the speedometer was inside the shack and was best around 30 MPH. We left it behind when we moved 10 years ago and there is another owner now and he has been using it.
Planer in Sawmills and Milling (forestryforum.com)
Heaps Planer in Sawmills and Milling (forestryforum.com)
DonP was a big help as were other members, some long gone now but missed.
This video was taken a few days before we moved in March 2010 where we made some flooring for the oldtimer that owned the land where we kept the planer. When we bought it from him 8 years before he told me I had to move it but when I asked him for an extension he said it was fine where it was. He liked the activity and we respected his rules. We gave it back to him when we moved and he has since re-sold it.
I'm on the infeed and Bob, the former owner is on the outfeed.
Heaps Planer.wmv - YouTube
Edvantage
Wow that's a lot of machine. I wouldn't worry too much about kickback I would be worried about getting wrapped in a belt or shaft. I'm extra cautious as I have my kids helping me. My ten year old is full speed eager to help and sometimes he's to quick. I'm constantly watching
farmfromkansas
Used to have a neighbor who built his own circle mill, and powered it with a 1066 IH tractor pto.  He had a planer also powered the same way, it worked well.
Edvantage
Just started looking at planer again as I bought 5mbf of white ash to mill. I'm planning to make 2" x6" t&g for my loft floor. The rest will be spiral staircase, interior doors,trim and kitchen cabinets. One way or another I've gotta have a planer.  As you can see in the picture you all where correct about the dangers of a square head planer. Someone put a lot of effort into putting ball bearings on this and than it looks like they had a jam and broke both blades. Who knows how long this has been sitting. I'm really torn which way to go on this. Trash it and find something else.?Or spend money on new cutter head and electric motor? The gas engine turned out to be a vertical shaft so scratch that idea.
Don P
 :o
Can't help with the hard decisions but awful glad you didn't spin that thing up!
Southside
That sure must have made someone duck, roll, and change their shorts!!!  That hard of a hit may have twisted or warped something else down the powertrain - just more food for thought.
@Paul_H What did you use the irrigation reel for?
Al_Smith
That old motor most likely is one of those massive low speed motors that wasn't build to be economical .You could always change it to something more modern .Although the cost of a new single phase motor most likely exceeds the value of the machine . I've got an old Crescent bandsaw and it is a heavy old rascal for sure .
tacks Y
I scraped one a couple months ago 3-400. Make a start on a good used one. I have a 24" Rockwell up for sale in Pa. If any interest I will post here and pay commission.
Edvantage
I checked out your ad looks like a nice heavy planer. Although I have a nice phase converter it's only rated for 5hp.  I have decided to scrap the one I have. The motor on a scale weighs 450.
tacks Y
Quote from: Edvantage on February 23, 2021, 06:29:27 AM
The motor should bring a higher price then scrap. So if off sell separate.
Don P
That Rockwell is a nice shop planer, I've run a bunch through one just like it, early 80's. Is your old motor up to being a phase converter?
Al_Smith
There's always again making a phase converter and using a 3 phase motor which could be another option .
On the subject in an old pattern shop owned by a guy who made patterns for Sherman tank castings  in WW2 he had a Oliver 24" planer and it was 5 HP with a massive motor , three phase .The guy who bought it had to hire a rigger to move it .heavy duty Judy .He also bought a 20" Crescent shaper which was 10 HP with no power feed .Widow maker if I ever saw one . That guy who has passed away since wanted me to half-fast wire them up ,I walked away from that.
I did buy some large lathe tool holders, live centers and what not for large metal lathes which I have used .Including a radius cutter which I could turn a trailer ball if I wanted to .--thus goes the life of a junk yard dawg .
muggs
My square head planer did the same thing, threw the thick slotted knife. Breaking the bottom table. :o
Edvantage
The more I dig into this the more it's looking like it's heading to the scrap man.
tacks Y
Most convertors are made to run an 1800 rpm motor if thinking of saving for that.
Edvantage
Motor is not usable. Broke it down for scrap armature is 200# windings are 150#. I think for a short term planer solution I'm going to buy an inserted planer head for the dewalt I have. My immediate need is to plane 400 pcs 2x 6" ash 8 feet long. 1/16 per side. Will serve as floor and ceiling.
Al_Smith
Quote from: tacks Y on February 23, 2021, 07:31:10 PM
I'm not sure it makes  any difference .I've made 15 or 20 convertors and have used 3450 RPM motors as well as 1750 and they all worked . 6 of one half dozen of another . ;)
Edvantage
Got $77.50 scrap price. Not much copper in motor mostly steel.
muggs
So what was the price per pound. I have a bunch of bad motors I need to take in.
Edvantage
.14 # for motor I  removed armature and windings they didn't want to pay for the iron. Was kind of scary deal was nobody around when I pulled up at scrap yard, then pick-up shows up with two guys and pistols in their hands which they quickly stuffed back in thair pockets when they saw I was bringing scrap. Looked like I walked into a drug deal? I was glad to get my money and be on my way.
muggs
Thanks for the info. They came out with guns in their hands!!!!! Man your scrapyards are rough. :o
