winter logging is about to start (I hope)
Started by Quebecnewf, December 18, 2009, 05:27:52 PM
Quebecnewf
Here are the pics of the completed sleigh
Any questions or comments
Quebecnewf
Mooseherder
It looks great and light weight also. The white shoe material underneath each ski must work like a charm.
Did you use teflon, Newf , on the runners?
Quebecnewf
No its not teflon though that would work as well. The plastic is called UHMW.
WE buy it in sheets of 10 ft and then rip it to the width we need
Quebecnewf
Teflon would be great for me to use, since they make it nearby. It's used on farm machinery sometimes to reduce wear on steel where rocks and mud ride along conveyors. My brother wants a small sled for his Elan. Don't know if I'll get to it. ;D
John Mc
We used to call UHMW plastic (stands for "ultra high molecular weight" plastic, if I recall) the poor man's teflon. Similar properties and applications as teflon, but a lot cheaper. We used a lot of it at work where we needed things to slide easily and without wear on the underlying parts. Not quite as slick as teflon, but it did the job.
DGK
Very nice looking sleds. What is the maximum weight that you load on them? Thanks for the photos.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
Quebecnewf
The weight you put on is based on many factors. The sleighs can hold more weight than you can pile on them in softwood logs. I have on ocassion towed 2 sleighs like this piled high with logs. I was hauling on the sea ice only at that time so no hills and it was a hard packed trail. When I arrived at the mill I would unhook one load to get up the small incline to the mill.
These types of sleighs are a fairly new way to move logs. The more traditional method was with a type of homebuilt sled called a kometick.
You can find pics of these on the net. They are still built and used here today for hauling firewood . They sleighs are only used for logging.
Quebecnewf
Kevin
If the back ends were sloped like the front they would be easier to back up.
motohed
It would be cool to see a load of logs on the sled . I am having a hard time being able to visualize how much you  can haul on the sled .
  Thanks Scott
Quebecnewf
here is an old photo of a loaded sled
Quebecnewf
Coon
What size and brands of snowmobiles do you use for pulling these loads?
Quebecnewf
I use a Yamaha VK540 this is a basic snowmobile that hasen't changed much over the last 12 years . Its a truck.
To haul decent logs you need a fair size machine. The smaller the machine the smaller the load.
Most machines these days are for sport not work so your choices are limited.
Quebecnewf
Coon
I hear ya on the snowmobile thing.....  I am thinking about converting an old snowmobile into a log pulling machine. The snowmobile I am looking at is no prize to look at right now as it is nothing more than a tunnel w/ track and suspension and skis.  I have an older 4 cycle engine that I would be mounting on.  I do not have a hood for this machine but would fab something up...... thinkin' it's gonna be a redneck build.....  :D
I have my skidding arch nearly complete and ready to roll with just a couple of modifications left to make.  This arch was specifically built for behind a snowmobile as we normally only skid wood in the winter.
Brad.
motohed
That pretty interesting , I would not have believed a snowmoble would pull that much . I guess you would have to have a pretty well groomed trail .
Quebecnewf
The trail is not groomed. You break the trail as you go in each day. Snow conditions vary from day to day and some days are great and some days not so good. Itake a load of slabs and stick them up along the way in across the marshes. This serves two purposes. One it helps to get you back home in a snow storm. Two when you have a fresh batch of snow you know that as long as you stay on the east side of the slabs your old trail is there under the new snow and this makes abig difference when your trying to make a new trail, your not starting from scratch. I also make a habit that each time i drive in i put one ski on the edge of the old track i made the day before and then drive with the outside ski of in new snow, in this manner i widen the trail each day.
Quebecnewf
With real cold temps like 0 F or colder, just disturbing the snow pack with a machine or sled will stiffen up the snow over night so it isn't fluffy. Stops the sinking feeling. :D Also real cold, wind driven snow, is almost hard enough to walk on.
Quote from: SwampDonkey on December 30, 2009, 06:53:45 PM
It's that "almost" that is a real killer  ::)  Like walking up a flight of stairs all the way in and out.
fuzzybear
I always break the next days trail before I quit for the day.  One pass with snowshoes just to find where I want the trail to be and then once or twice with the skidoo to pack it down.  Makes the next day start easier.  That is until mother nature sends in high winds and blows ALL the trails shut again. >:(
I never met a tree I didn't like!!
Quote from: beenthere on December 30, 2009, 10:00:40 PM
It's more like the "yes mamms" the wind makes for the sled to bump up and down on that could be the killer. "I think my liver moved" :D
bushmechanic
Hey quebecnewf this is bushmechanic,another newfie and new to the FF.I am from the east coast of the island and am well aware of snowmobile logging.I was wondering if you had a pushbench sawmill,I don't guess that is common anywhere else,I don't see anything else on the internet about it.
YukonJon
Interesting to see a home built sleigh of this type. I was wondering if you use springs on your sleigh hitches and if so where do you get them?  Do you use a swivel on the front log bunk?  What do you make your draw bars from?
I recently started using a snowmobile for getting firewood and am gearing up for getting saw logs with it.  Prior to that I was using an argo with tracks.
Jon
Quebecnewf
I  have seen those pushbunk sawmills. Way to dangerous for my part . I will stick to my bandmill.
Some guys use springs on the tow bar but not too many are making new tow bars that way. The cross bunks on my sleighs are made of angle iron welded back to back. I do not put a swivel on my front bunk. There is enough give in the lashing line to allow the sleigh to twist and turn as needed. I had a swivel on my first sleigh I built but it was too dangerous. You would forget yourself when loading logs on the sleigh and step on the bunk and fall down very quickly.
Quebecnewf
Coon
Did you manage to get enough ice to start up your operation....
Newf is probably in that warm spinning LOW up that way that we have been experiencing. Too mild to freeze up.
