Daily carnage thread
Started by mike_belben, July 23, 2018, 11:44:49 PM
Ljohnsaw
Quote from: mike_belben on October 11, 2018, 11:01:34 AMMy goal is to never leave home and work every day.
That is why I collect/save every nut and bolt I come across.  All somewhat organized that I can usually find what I need:
Probably 5,000 pieces :o  I still have another 10 or 20 jars of "collections" to sort through.
John Sawicky
mike_belben
Organization is key!   If it takes you 3 days to stumble on the thing you know you have, a trip to town is a better value.
I have the primary stuff in bins and get by pretty well.  I manage to group things well enough that if i find the group, ill have every nut and bolt from that chainsaw thats been moved across the country and been apart 5 yrs. My problem is no shop and still half way moved.  I have hardware store bins to put up once im settled, then i will start sorting the 5 gallon buckets of 30cents/lb scrapyard hardware. Money doesnt matter that much in the country.  You and your neighbors get by trading mower blades and weed wacker coils. Junk is important here.
And your setup looks great john!  I have order envy.
Praise The Lord
g_man
Blown hose?
I am pretty fortunate to have a hose maker, dies and a lot of ends.  It took about 5 yrs to collect it all and gets me out of most jams.  Fortunately there is a great hose shop about 30 mins from me when i cant cobble something.
My goal is to never leave home and work every day.  I avg about 1 to 2 week stretches.  Most of the bits i need come in the mail.  Saves me a lot of half hour trips to town.
You got it. Replaced all three. Never left home. DiscountHydraulicHose.com. Ordered Friday got hoses Tuesday. Regular US mail.
They been there a while. Lots of PB Blaster and a "Box" Wrench.  :D
gg
nativewolf
Man, I guess I need to take more pictures.  Mike is too *DanG far ahead and probably 10x the mechanic.  For instance, I spent 10 mins trying to get an oil drain plug off the morning.  Have to go back with a pipe for leverage.  Someone must have tightened it on with an impact wrench.
Took Mikes advice though and pumped the hydraulic and fuel tanks empty after I ripped 3 hoses off on the forwarder crane, found the hydraulic tanks nearly empty (not from me) so it was worthwhile getting them clean.  Diesel tank is clean too (cheap harbor freight transfer pump does wonders.
Liking Walnut
g_man
Quote from: nativewolf on October 11, 2018, 12:10:36 PM
Pictures are good - that way you can figure out what you were doing when you wake up from your nap.
gg
Hilltop366
Quote from: mike_belben on October 11, 2018, 10:54:27 AMWell then dont take this the wrong way, but Im actually a pretty good mechanic
I figure you know what your doing Mike, with used equipment you inherit not only the design flaws of the manufacture but also the misuse and abuse and half baked repairs of the previous owners, the only reason my old backhoe does not break more often is I don't use it often.
kiko
Satamax
newoodguy78
That has an expensive look about it
mike_belben
The Least Likely To Buff Out Award goes to KIKO!
Praise The Lord
barbender
That looks like a "it was making a noise, so I turned up the radio" type of mechanical failures!😂
teakwood
nativewolf
Quote from: kiko on October 11, 2018, 03:06:47 PM
Planetary carnage.
"what's that? Speak up this machines been making a helluva noise for 2 weeks now"
Liking Walnut
51cub
I'll have to start taking some pictures around here. A few years back one of the drivers came in 3 times during the same storm with the right rear outside wheel in a perfect triangle- never hit nothing. Another tore a hydraulic tank off the truck. He didn't think he'd hit anything that hard. Won't even talk about what some of the plows come in looking like
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
If nothing else I'm always a good last resort or the guy to hold up as a bad example
Oliver05262
   Real special to come in the shop and find this. One of the herders left his truck (loaded) in front of the door and put this PTO shaft and
 hose on the floor for someone to deal with in the morning...............
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
mike_belben
I thought you were building some rod iron house plant arbor there for a minute.
Praise The Lord
At a quick glace I thought it was a hyd hose.  :o
Hilltop366
I believe I still have a matching drive shaft to that one in the junk pile somewhere if you need a pair.
kiko
mike_belben
Nah just underweldered.   ;D
Praise The Lord
barbender
I can't believe the stuff people can break!
Gary_C
He could have been trying to pull stumps. If you can't lift them out, try driving away. :)
GRANITEstateMP
If you stand farther away when you take the picture, it'll look better... Maybe not
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
KWood255
Turns out that I didn't really need to turn up the hydraulic pressure on the tractor to split some huge pine logs....
mike_belben
Its split alright.  We will rebuild!
Praise The Lord
