Parts
Started by Peter Drouin, January 04, 2023, 07:44:24 AM
Peter Drouin
My 3500 GMC needs back spring perch on the end of the frame. GM doesn't make them anymore.
Anyone know where on the web I guy can get parts. I looked and all I see is the plastic stuff, lights, bumper, fenders. No frame stuff.
Thanks for your time,
A&P saw Mill LLC.
License NH softwood grader.
moosehunter
We have a local truck spring shop that can usually find things like that. Allied Spring. Syracuse NY.
mh
Higher than my expectations
doc henderson
LKQ online
lkqonline.com
all the junk yards.  fill out a form and start getting calls in a few hours with price and shipping.
chevytaHOE5674
If your talking the rear hanger that the swing shackle attaches too then go to LMC truck they have what you need.
Home Page
doc henderson
what year?  they no longer make the taillight assembly for my 2007 classic 3500.  I have used LMC for older stuff.
doc henderson
mudfarmer
Peter check on rockauto.com that is where I have been getting stuff for years. They had that same part for both of my old Fords. Those dang upside down spring hangers hold salt and sand and water and just rot right out :(
B.C.C. Lapp
Tell you one thing. If I was opening a dealership I'd get Doc H. to be my parts man.
Listen, or your tongue will make you deaf.
Resonator
He's not parts counter, he specializes in body repair. ;D
alan gage
Unless there is something odd about this year i'd expect them to be available via the aftermarket. We replace them now and again. Look for "leaf spring shackle" and see if that gets you in the neighborhood. A good parts store should be able to help you out too.
Replacing them isn't for the faint of heart. The bolts tend to seize in the bushings and can require a lot of persuasion. We've removed the truck bed on the last few for better access.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Peter Drouin
Thanks for all the help, guys.
A&P saw Mill LLC.
Bruno of NH
Rock Auto might have them as well
Peter Drouin
A&P saw Mill LLC.
GRANITEstateMP
Donovan Spring in Londonderry might be worth calling Peter.
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Bruno of NH
Quote from: Peter Drouin on January 04, 2023, 02:06:10 PM
Is that in NH?
It's an on line Auto parts place
I have had great luck with them
Bruno of NH
What year is the truck ?
Walnut Beast
Have you looked at any you buy it you pull it junk yards. Where you do it, Some will pull and ship parts
JJ
another source is Palmer Spring in Portland ME
https://palmerspring.com/
They fabricated a bunch of suspension parts for my 1980 K5 Chevy but was many years ago.
Shackles and leaf springs.
I live in Londonderry, I can check on Donovan Spring if you like.
       JJ
Peter Drouin
I will call Donovan tomorrow, I forgot about them.
I do have a bunch of catalogs coming. Now :D
I'm thinking of taking the bed off. I looked today to see how to. It has to all come off the frame. The dump pins are welded in place. So is the dump piston. 2 halves, bed and bottom.
4 bolts, the backlights, Gas fillers--2, Wires for the hydro. Some straps and the 1044 will lift it off.
Well, that's the plan.  :D
That way I'll fix the truck, needs a muffler too.  Then bring the dump in the shop, set it on some legs, cut and weld, want to set it up differently.
It' a 2005  3500 4x4 5 speed standard with 70,000 miles on it.
I love the standard part, My 2006 2500 4x4 is a 5 speed too.
Hot Rod is sitting there looking at me all pith off. :D :D :D :D  I put the car cover on it, so it can't see me. :D ;D
A&P saw Mill LLC.
doc henderson
that pic was from LMC truck, and the price is on the next page in the online catalog.  what part, by number in the pic are you needing?
Bruno of NH
Rockauto has them for your truck $219.00 plus shipping
Peter Drouin
12-13--The bolt might not be good after I pull it. 9 is what I need to replace.
Thanks, Bruno. Looks like $500 in parts, I need 2 not bad.
A&P saw Mill LLC.
Bruno of NH
They are good about shipping
It's always worked good fir me
Peter Drouin
Coming slow, Fools welded where the hinges are to the frame. :o
Got it off.
Clean up the back of the frame.
 You can see how bad the rust is. Getting new hangers was a pith, Tried a lot of places. They all had the small set, I needed the big ones   I did find them at Rock auto, Thanks Bruno there on the way
Truck show up, can't get away from the sawmill in your backyard. :D ;)
22' W Pine for a timber frame in the spring.
Have to replace the muffler too.
Pore Hot Rod just sets there all pith off. >:(
A&P saw Mill LLC.
barbender
Poor hot rod!😂 I've had good luck with Rock Auto as well, I got replacement hangers for my 97 Dodge 3500 from them a few years back.
