Accuset Bypass
Started by Kemery, January 17, 2013, 09:49:57 PM
Kemery
I am operating an Woodmizer super mill with accuset and yesterday I shut it down to change a blade and when  I went to start it back up again there is no display and the up/down wont work. I called Woodmizer today and they say its the accuset control panel, I have heard that you can bypass the accuset and operate manually. Could any of you tell me how to do this? Need to finish an order... any input would be greatly appreciated!
Chuck White
Welcome to the Forestry Forum, Kemery!
I'm not at all familiar with acccuset, but someone who is will see this post and hopefully help you out.
sparks
If you walk with the mill, as you saw, you can take the wiring diagram of the mill and rewire the sawmill like the diagram shows or take the Accuset manual and follow the installation instructions backwards. If you stand in one spot when you saw you can not bypass the Accuset.   Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
fishpimp
Kemery
Thanks for the info! I will be trying this first thing Monday, sure I'll have more questions as I go....
Kemery
Hey Sparks, you wouldn't happen to have one of those wiring diagrams in in a pdf or other format you post on here for me do you? thanks
Kemery
*could sorry for the typo
