quater scale on a Wood Mizer Lt 40
Started by Tim Lea, January 22, 2013, 11:55:00 AM
Tim Lea
When I got my saw it was second hand it didn't have quater scale on it. So i got one for it but am not shore where to set it to the inch scale. And second not for shore on how to use it when it is set.. I know it will make life beter but just haven't had anyone close to me to see it used.. Thanks
WH_Conley
If your mill is adjusted correctly the inch scale will be exact distance from a down turned tooth to the bed rail, when the blade had tension on it. The quarter scale on 4/4 lumber should be set at  1 1/8 to 1 3/16 inch on the inch scale. The scale should have several boards laid out on it. Just drop from one mark to the next.
Bill
Tim Lea
Thanks, thats what i thought but wasn't shore..
Qweaver
My WM quarter scale is a magnetic tape that sets beside the inch scale.  So you just slide it up or down on the cant to start your first cut.  Works great that way.
