UPDATE: Struggling with Forest measurements class..
Started by BrandonTN, September 19, 2008, 11:41:32 PM
BrandonTN
 :( Yes, it's true. In my current principles of silviculture class, we have to write lab reports and abstracts describing stands we visit and whatnot. I used to be an English major back during my 1st attempt @ college 7 years ago. I thought of myself as a good writer....well, my idea of a good writer then being Jack Kerouac or James Joyce, ie anyone "creative", stream-of-conciousness style.
But the technical side of things have finally caught up w/ me, and have shattered my perception of myself as a writer. ::)  ...ego is deflating as I type this.  :-[
Organizing the scattered knowledge in my head into concise, flowing, technical writing is hard for me.  For one, I think if I knew more about what I was writing about(terminology, processes, etc.) would help bigtime.  I simply have a hard time wording things concisely it seems.  Then there's the switching phrases around like this:
"Responding to a clearcut, hardwood species regenerate by root sprouting."
"Hardwood species regenerate by root sprouting, responding to a clearcut."
Which is the best way?
This isn't the best example, but I struggle with this when I have a paragraph worth of things I want to say in my head, but I seem to either have too many run-on sentences, or too many short sentences...I struggle finding the balance.
"Brevity"...i looked up the word in the dictionary: "Saying much with few words." That's my goal, but I'm the opposite of that right now. I'm used to writing English papers where writing descriptive fluff is the name of the game. I'm gonna have to spend more time learning to write then I thought.
Anyone else have this problem in forestry school? Is there hope? ::)
Forester, Nantahala National Forest
Is there not a technical writing class in forestry now? Technical writing is almost like writing a thesis incorporating the scientific method, in it's structure and flow to things. Grammar is very important, not just that you can spell. Organize your thoughts with an opening theme to every paragraph and build on it. New theme or thought, new paragraph.
It flows as follows:
Purpose/Introduction
Materials and Methods
Description
Results
Conclusions
Literature Cited
The conclusion is where the professor sees if you understand what you actually did. Probably the most important for the grade.
There is no way you can just sit down and write one up in a session, there is a lot of work placing thoughts with one another that follow the same theme. I always wrote stuff by pen first and then put it to word processor, because a lot of information gathering is required at times, later condensing and fitting it together as you build the report.
cheers
Yes, there is hope.
Write the paper first in outline form that shows the organization as SD suggests.  Fill in the outline with the key facts/points that you need to make.  Then, write the words that make the points and conclusions.  You build it up like putting flesh on a skeleton or like adding walls to a foundation.
It helps if you can see this organization in your head before you ever begin writing.  If you can develop that structure, it is easier to be more creative with your words and sentences since the structure (skeleton) keeps you from inadvertantly adding a third leg to a two-legged individual.
Also, like you said, no fluff.  "Just the facts, Maam" to quote a famous TV show.
A good friend of mine has written a book on communication in Forestry.  You might give it a try.
http://www.amazon.com/Loving-Trees-Enough-Communication-Professionals/dp/1593304285
Gary_C
Quote from: SwampDonkey on September 20, 2008, 06:00:04 AM
Description
Results
Conclusions
Literature Cited
I would add one section right after the Introduction called:
Summary and Conclusions
While it may seem wrong for you to reveal your ending at the beginning, most of the readers will appreciate seeing what they really need to know first so they can better follow what you did to reach that conclusion without flipping pages. And probably over two thirds of the readers will not need to read past that point.
Plus writing the end first can help you organize your facts to prove your conclusion.
Yes, Gary. But, a more appropriate term might be Abstract. All technical papers have an abstract that does what you ask. While I had thought of it while jotting down the list I never included it as most laboratory exercises in college omit it. If your asked to write a paper on a topic, then an Abstract is included. Often the only direction you get from the instructor is a one or two line question for you to postulate and cogitate over. :D
BrandonTN
Ok, I'll try starting with the outline. I've basically just been going down the list of sections, and writing it as I go.
phew! thanks guys
Brandon,
I want you to know that I had the same problem.  You can do it.  I did.
Me to Brandon, but I always found if you like a subject more you do better in writing it up. I used to ace my out door soils lab writeup for instance, but when it came to the second course on analyzing the soil and using the computer models. Ho Hum!! Guess I'd rather get my hands dirty. :D
Riles
I used to write short, factual sentences on the first draft and then pretend I was saying those sentences to the professor in the rewrite. Found my writing style changed based on who I was "talking" to.
Knowledge is good -- Faber College
BrandonTN
Thanks guys for reassuring me on the writing.  :)  I got a good grade on the last report so I'm feeling more hopeful.
But Measurements and Sampling class is a different story.... :-X :-\
I'm pretty sure I bombed the Mid-term today. I'll be happy if I passed by 1 point. I blame my own neglect of studying more than the mind-numbing nature of statistics...this time, atleast. ;D But yeah, even though we were allowed a whole "cheat" sheet front and back to prepare for the test, I still bombed it. I thought I understood Confidence Intervals, and all that jazz better than I did. (I got a B in reg. intro to Stats.) But apparently, this stuff doesn't stay retained for long w/o regular use. Plus, in the intro class all the formulas we needed were supplied at each class, and it seemed simpler, and more generic.  It's tough!
Wake up call! Time to start working the problems in the book.
So, we need a more studious Brandon ;D.  Nose to the grindstone ;D ;D.
BrandonTN
You got that right, WDH. ;)
smiley_computer_monitor <---- Me doing my homework on Excel.
We're pullin for ya Brandon.
And thinkin how great you have it with the calculators and computers to do all the messy sums of squares, and square of the sums, etc. etc. etc.   ;D ;D
(or do they make you do it by hand, just so you feel the pain.. ??? ??? ::) :)  ).
A whole lotta things you measure in forestry will need the statistics applied to them and as well, interpreted from sampling...so doin those problems and knowing them will help you a lot.  :)
tonich
Quote from: BrandonTN on October 20, 2008, 10:25:18 PM
And we all trying to help:
PS. J/K  ;D :D :D :D
Oh, you mean Biostatistics. ;D  I thought we were talking mensuration for a while there. ;)  How is your poisson distribution? :D
If I had a poisson distribution, I would fry it up and have it with chips ;D.  J'aime le poisson.
Texas Ranger
That was the class, in my day, that separated the men from the boys. :'(
Riles
Sometimes I just gotta scratch my head. I'd also like to say that when it comes to mensuration a professor can even make the proper use of a compass seem like rocket science. I never could understand the reasoning behind it. But, then you get into Tom's prism thread and you better study up and practice or you can get lost quick. Once you know the stuff it seems simple as long as you use it often enough to not loose the knowledge.  ;D
Rocky Top
Description
Results
Conclusions
Literature Cited
This is the biggest thing for Silviculture (Clatterbuck right?) make sure you are breaking your paragraphs into the format above or the one given to you by your TA in your first or second lab for the semester.  Have you had the wildlife management principles course I believe it is FWF317 taught by Dr. Buler and Dr. Strange?  When I was there it was the best class to really teach you the technical writing style.
clearcut
My favorite references for Forestry Statistics are:
Elementary Forest Sampling, Frank Freese, Southern Forest Experiment Station, Forest Service Agriculture Handbook No. 232, December 1962, U.S. Department of Agriculture, Forest Service
and
Elementary Statistical Methods For Foresters, Frank Freese Statistician Forest Products Laboratory, Agriculture Handbook 317
U.S. Department of Agriculture Forest Service
January 1967
Simple, straight forward and available as a PDFs:
     http://www.fs.fed.us/fmsc/ftp/measure/cruising/other/docs/AgHbk232.pdf
     http://www.fpl.fs.fed.us/documnts/usda/ah317.pdf
Carbon sequestered upon request.
'Ol Frank was a straight forward guy..and had a remarkable ability to take something complicated to most, and say it (and write it) in few words that made a lot of sense.
He was a very good, and close friend.  Lost him to cancer in Nov. 1996.
Frank went to Forestry School at Syracuse, then ended up in the army during WWII, and was in the thick of things during the Battle of the Bulge.
Returned from the war to work at the Southern Forest Exp. Station with Lou Grosenbaugh. Moved to the Forest Products Lab in Madison in early 60's.
Glad to hear his Sampling and Statistics pubs are still well thought of.
Thanks for the info, clearcut
Chris72941
Hey Brandon
I will be transferring from University of Arkansas Fort Smith to University of Arkansas Monticello this spring(if all goes well got to love this economy >:( ) Anything a Forest Resources newbie needs to know when getting started on Forester w/GIS minor?
BrandonTN
Quote from: Rocky Top on October 22, 2008, 09:06:38 PM
Description
Results
Conclusions
Literature Cited
Nah, I haven't taken the Wildlife class yet.
Quote from: beenthere on October 22, 2008, 11:41:04 PM
My class went to the Southern Forest Exp. Station in NC last week....Dr. Loftis talked to us.
I'd love to do a summer internship there this summer.
Quote from: Chris72941 on October 24, 2008, 12:32:58 AM
Hey Brandon
Greetings Chris! Just be prepared to study and take good notes and you'll do fine. Also get involved with the forestry club at your school, and participate in Conclave--(the annual competition of all forestry schools in the southeast....lots of fun!) I may see you there sometime actually. I know Arkansas went last year. It may even be hosted at Arkansas next year.
I hear GIS is a good skill to have.
Over the past year and a half that I've been here at school my direction has changed some. First I started off wanting to minor in journalism. Then it was journalism and english. Then it was journalism, english and wildlife. Then I heard about forest-fire fighting, so I wanted to forget the minors and get done w/ school sooner. Now I'm planning on not minoring in anything, studying abroad next year, and then grad school after that. And work in fire if I can.
So things may change some. So, expect the unexpected.  ;)
