Bleaching blue stain in white pine.
Started by Dave Shepard, July 23, 2024, 09:40:07 PM
Dave Shepard
Has anyone had any luck bleaching blue stain in white pine. A little blue is ok, but some of the timbers are black. Thanks.
Hydrogen Peroxide or  Oxalic Acid may work, I suspect results will vary. May require more than one application to.
Dave Shepard
Thanks. I don't remember bleach doing very much. I'm not trying to eliminate the stain, just knock it back a bit.
fluidpowerpro
I've done it on Red Pine. Put a mix of water and bleach in a spray bottle and spray it on. Multiple applications will be required. It seemed to me that direct sunlight helps speed to process.
Change is hard....
Bruno of NH
Dave Shepard
KenMac
When searching "wood bleach" I found that oxalic acid is sold as wood bleach. That would be where I'd start testing.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB, Takeuchi TB260C
I was thinking that blue stain is hard to alter, according to, I think to Dr. Wengert
raw and with butcher block oil.
jpassardi
I might have to get one of those engravers like you have Doc.
Stephen1
I just received a load of EWP. I don't really have a choice on when they come as I buy all my logs from a local Arborist who uses a mini Ex on all his job sites. Had an order for some EWP beams and asked if he had some logs, boom... 2 days later here is what I have. He wanted to bring another 2 loads but I had to refuse. Hard to saw no.
My real question for you guys is ...Can I turn my sprinkler on these logs to prevent blue stain in the logs. It is town water so it has chlorine in it. And how much do I have to spray on it?
What can I spray on the lumber when I saw it?
We are in the heat and humidity of summer up north here, 80-90F and lots of humidity, not quite what some of you southern boys have but hot for us up north.
