Author Topic: DT 466 getting harder to start  (Read 2676 times)
Offline sawguy21
Re: DT 466 getting harder to start
« Reply #20 on: March 27, 2021, 10:12:58 PM »
Be careful with ether, if ignited by the glow plug hard starting will be the least of the problems.
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« Reply #21 on: March 28, 2021, 12:56:10 AM »
If using it in an engine with a heating type element of any sort, the engine is turning over before you 'fog' it in as @mike_belben mentioned. If an engine doesn't have any type of heating element, then one can spray it in before cranking, but just enough cannot be expressed enough here.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #22 on: March 28, 2021, 01:25:27 AM »
It's amazing how this old thread brought up so many good memories of multiple International engines including the DT 466 which has been called a Legend.
Building The Legendary Navistar DT466
THE INTERNATIONAL/NAVISTAR DT466
It's also ironic the post that brought up this old topic is not about the inline 6 cylinder DT 466 but the V-8 T444E which is better known as the 7.3 Powerstroke. The commonality is the later versions (1995 and up) of the DT 466 had a new designed head and the HEUI injectors developed in conjunction with Cat that were also used in the 7.3 Powerstrokes.
What makes it even more interesting to me is my still remaining connection with many of these IH/Navistar  and now Case/IH engines. I still have an older Case 904 cid engine that was the base engine for the upgraded engines in the Magnum series of tractors. I also have a DT 466 in a 2+2 tractor, a D436 non turbo engine that needs new sleeves from a IH 1440 combine that was replaced with a newer rebuilt DT 414 from a IH 960 combine  and a DT 414 in a 1086 that has T/A and tire fluid problems. None of these engines are currently operational and are old retired man projects on the shelf.  ;D
Offline mike_belben
  • Pulp Friction
« Reply #23 on: March 28, 2021, 02:21:44 AM »
After the DT466 A, B and C models came the "NGD" for new generation diesel.  It used a 12mm bosch P (or maybe an A? Cant recall) injection pump mounted up higher than the prior MW pump, and the intake goes into the head.  That is 95-97 im fairly certain, then was replaced by the DT466E.  The NGD is extremely good but south america has consumed most of them.
The 466C and older has a 3/8 valve stem and ran only an oil deflector shield because its a low pressure drizzle system..  The NGD has a high flow oil system to the valvetrain and switched to oil seals then to smaller, lighter valve stems. But there must have been an early run of 3/8 stems in the NGD because every aftermarket gasket kit for any 466 will come with shields and seals for 3/8 stem.  If you put seals on a 466C or earlier it will starve the valves until they eat through the guide, into the head casting, and into the tops of the bore liners and piston relief pocket.  It took under 4000 miles on a brand new out of frame for this to happen to me.
New oem headbolts are NLA and foreign ones suck so dont lose your oem headbolts.  No one makes alloy stud kits that will last for road miles.. Theyre sled puller stuff thats junk after a season or two.
Psalm 37:16
Offline farmfromkansas
« Reply #24 on: April 02, 2021, 08:44:36 PM »
I had an old 986 farm tractor with the 466 engine, it started up easily, even when pretty cold.  Think it was a 81 model.  Engine was great, but you could not shift gears without grinding.
Its getting harder and harder
Started by lyle niemi on Sawmills and Milling
Last post March 04, 2013, 10:47:38 PM
by Chuck White
The ground is getting harder!
Started by Banjo picker on General Board
Last post September 19, 2009, 08:51:00 AM
by Banjo picker
Are knots really harder? And if so, why?
Started by alan gage on Sawmills and Milling
Last post March 22, 2021, 05:47:42 PM
by justallan1
Work smarter not harder.....
Started by Jim_Rogers on Timber Framing/Log construction
Last post January 14, 2013, 01:02:37 PM
by 4speed
