Coil/Igniton Module Mods
Started by Kiwi_21, October 05, 2019, 11:12:11 PM
Kiwi_21
hi guys im new to this site an im wanting to know if anyone has tryed using a coil upside down an still works or does it have to be up the right way for the north an south magnets on flywheel cheers Bart
luap
Not sure what you mean by upside down. I don't see it working any other way from what the factory intended. Not a chainsaw but a small engine, Briggs and Stratton offered a kit to convert older point ignition to electronic. It required changing the polarity of the magnets on the flywheel which they would do for no charge but you had to send it to them. Some smart guy discovered you could flip the coil 180 degrees with the same result.  Some small engine coils have an" in "  and " out"  printed on them and my Husky coil can only go on one way.
