Logging Biger is better right???
Started by smwwoody, February 04, 2012, 07:16:39 PM
Okrafarmer
Dixmont! You've got to be kidding, I grew up in Clinton, just three towns away. We knew people from Dixmont.
The old title info in the glove box indicates that before the people in Georgia had it, it was registered in Mississippi....
Now selling Logrite tools!
Okrafarmer
Quote from: Okrafarmer on February 09, 2012, 07:41:27 PM
How can you be sure it's the same one??
Woodhauler
Quote from: Okrafarmer on February 09, 2012, 07:49:05 PM
I am 100% sure! Whats the name on the title?
2013 westernstar tri-axle with 2015 rotobec elite 80 loader!Sold 2000 westernstar tractor with stairs air ride trailer and a 1985 huskybrute 175 T/L loader!
Woodhauler
Quote from: snowstorm on February 09, 2012, 07:38:59 PM
Quote from: Woodhauler on February 09, 2012, 07:27:05 PM
Quote from: Okrafarmer on February 07, 2012, 09:43:13 PM
Ok, let's see how this works. Here is the GMC log truck we've been using...
And here is the White just obtained Saturday.
;D
That ole white belonged to a guy in the next town over from me!!! Its along way from its old home in dixmont maine!!!
was that guy from brewer? back in the mid 90's had a tracked shear guy asked me to cut chip wood for him. seems like it said alpine on his trucks
Yes snowstorm that is him! What was his name? Bill maybe?
Okrafarmer
Woodhauler
Okrafarmer
The farthest back I know is that it got registered in North Port, Florida around Oct. 15, 2005. That is a solid month and a half after Katrina hit New Orleans. North Port was not in the path of Katrina. The name on that registration was Alpine (Industries, I think). No personal name. If the truck came down to the gulf for Katrina from Maine or anywhere else, it seems strange for it to be registered in North Port (just south of Sarasota) when it did. If it had been registered in Pensacola about that time, then that would be more understandable for the Katrina scenario. I haven't the foggiest notion what happened with that truck before Oct. 15 2005. Except for what you are telling me... do you have any way to verify that?
mainiac
Woodhauler did say his trucks said Alpine on the doors.
Not one shred of evidence supports the notion that life is serious.
snowstorm
this mcnutt guy moved around a lot. he asked me the cut chip wood for him. i would say mid 90's. said he was from alton was renting a garage in brewer and ron says he lived in dixmont. at one time all his tired iron was at dysarts. seems like it was there a long time.
Okrafarmer
Hmm, the plot thickens.  Well, it is obvious that this truck has moved around a lot! We took it out yesterday to try to pick up a huge stump, and failed. Looks like we either need to do a little tinkering on the hydraulics, or get in there and knock all the dirt off the stump. We broke the shear pin holding the PTO shaft, and red-necked it back together enough to put the grapple away, then drove back home. (Used our part-time CDL driver). We might have tried some more things, but the driver had to get to a commitment-- he's a busy one! We are needing to go get our CDL road tests. Won't be in that rig, though. We have a newer truck we're fixing up for that.
Okrafarmer
Yes it is a Prentiss 110. We are having problems with the pivot gear (rack and pinion). It is binding up and popping. I guess we will have to replace or resurface the gear and/or rack. We will be doing a full inspection on it before putting it into serious use. But we did manage to go pluck a huge stump with it, its first payload for us. Uh, in case you were wondering, no we did not dig the stump out with it. The stump was already loose. We were just paid to haul it off.
snowstorm
the G i had back in the 70's broke the peice the loader pivots on. it was fairly common. after that had a 110 it was better. the a frame cracked on that one. not real bad the 110 was far better than the g
Maine372
make sure the collar under the a-frame is tight. slop there could lead to the rack and pinion skipping.  we acutally used to dig stumps with ours. you had to be a little circumspect, digging around and breaking each root. we also set trusses, built rock walls, hauled sheds, and many other things with the old 110. looks like it had the same grapple as yours too. grease it good and often. it may be slow but its strong.
