New to Milling - Possible With Hand Tools?
Started by MT, August 09, 2020, 07:38:48 PM
MT
I'm interested in getting into milling my own lumber. Is it possible to mill boards with an axe/wedges or frame saw?
btulloh
They used tools like that several hundred years ago.  Not much production or very accurate, but you can do it.  Plenty of exercise for a few bits of lumber. Just depends on what you want to achieve.
A chainsaw mill is probably the lowest cost method in use now. Still plenty of labor.
What is your objective for the lumber you will be producing?
HM126
terrifictimbersllc
Sure, but why would you want to?
Google "2 man pit saw", look at images.
I wouldnt call splitting a log milling though it can also be done.
Free hand chainsawing would be faster than either, if the noise doesnt work for you, can get electric or cordless one. Depends how much work you want to put up with to get a board.
Freehand chainsaw milling is still done in many parts of the world.
mike_belben
Riving whole logs is ridiculously hard unless theyre very straight grained and free of knots.
You can noodle out useable rough boards with a long bar and some practice, or hand hew logs into framing cants.  Tried that once too.  And did one face with an old one man crosscut also to demonstrate to my boy what death by homesteading looks like.  Any of these is gonna take years off your shoulder sockets.
What are your wood needs and what is your fabrication ability?  Have you got a chainsaw?
Praise The Lord
MT
I don't have a chainsaw. I was wondering how you could get 4/4 boards out of 4-6' cherry or maple logs. I can't find any videos on riving anything more than short logs.
After a board is riven, can it be passed over a jointer or planed down to make a smooth surface?
Ultimately I plan to get into chainsaw milling but wanted to try it this way just once out of sheer curiosity.
btulloh
If you're gonna rive out a few boards, you should follow through by using a scrub plane, then a jack plane, and finish with a smooth plane. Use a plumb line to mark the ends to describe the finished surface. Connect with a straight edge on each side, then plane to the line.  When one face is flat, mark all around with a marking gauge for the finished thickness, then plane to the line on that face. When you're done you'll have a board and strong desire to buy a mill.
It's not a bad idea to try out the old ways. Makes You a better craftsmen with a better feel for working wood.
HM126
mike_belben
Quote from: MT on August 09, 2020, 09:56:51 PM
Screw a 2x or piece of angle iron etc as a guide to the log, run a circular saw as deep as itll go to make a straight slit.  Then either flip and repeat with a chalkline and finish with a handsaw or rive it via the slits.
I think a froe is what you wanna rive with in that circumstance.. You can steer more than by using wedges.  For split rail i stand the piece up and stand on a trailer to hammer downward with my back straight.
Praise The Lord
mike_belben
For boards out of short bolts a regular vertical bandsaw with a fence should work.
Praise The Lord
Don P
I worked on an old barn a few years ago. Mainly log, there were no saw marks on the original stuff. The roof purlins were all rived and quite a quantity but it was all chestnut which does work well with that method. Straight grained red oak would probably be my choice of readily available wood nowadays for trying that.
Jim_Rogers
I think Mr. Chickadee did a video or two on doing that. He's on youtube.
Jim Rogers
