Author Topic: 1978 Cat 518  (Read 6670 times)
Offline Ohio_Bill
  • Wood is Good
1978 Cat 518
« on: September 16, 2011, 01:32:28 PM »
A farmer near me has this skidder for sale . He has had it for several years and has logged about  100000 ft a year with it . Tires are like new and he says it works fine . He is asking 16000 . I donít know anything about CAT skidders and would appreciate  any  advise
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor Ė Loader ,Bob Cat 763 , Riehl Steel Edger
Offline 240b
Re: 1978 Cat 518
« Reply #1 on: September 16, 2011, 01:49:15 PM »
look for cracks were the front axle bolts into the frame.  air brakes?
Offline sealark37
Re: 1978 Cat 518
« Reply #2 on: September 16, 2011, 01:53:24 PM »
Have a close look at the pin and bushings that make up the steering pivot point.
Offline Bobus2003
Re: 1978 Cat 518
« Reply #3 on: September 16, 2011, 09:11:01 PM »
Cat 518's are notorious for loosing brakes.. The 3 I have ran haven't had brakes, They are a bit hard on fuel. At least compared to my JD 440 and the TJ 450 At work. A thing I have also noticed is they tend to crack out where the blade cylinder meets the blade
Offline duckslayingpro
Re: 1978 Cat 518
« Reply #4 on: September 17, 2011, 11:22:51 PM »
If the frame and pins check out motor tranny and winch are sound i would say go for it! My father-in-law used one for many years. Absolutly swore by them. He pulled about 15000 ft of ozark hardwood everyday. Good machine.
Offline Ohio_Bill
  • Wood is Good
Re: 1978 Cat 518
« Reply #5 on: September 18, 2011, 06:26:19 PM »
Thanks everyone for your recommendations. I will go back and inspect it looking for the things you all have suggested.
Bill
Offline Don K
  • wanna lick some wood??
Re: 1978 Cat 518
« Reply #6 on: September 19, 2011, 08:16:19 PM »
My Grandaddy made a living with one from 1974 until he shut down his operation in 1981. Never had a major problem that I remember, but he always maintained his equipment very well. Usually got top dollar for everything he sold.
Don
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
Offline treefarmer87
Re: 1978 Cat 518
« Reply #7 on: September 19, 2011, 08:53:03 PM »
that is a good looking machine :) i notice there is a tarp over the winch-good sign :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Offline John Woodworth
Re: 1978 Cat 518
« Reply #8 on: September 24, 2011, 11:47:24 PM »
The 518 is a good machine but you had better have the wood to yard as they will do 30 to 40 gallons a day with serious yarding, I spent 2.5 years on one with grapples and winch, very good machine but they don't seem that noisy,don't let that fool you,it sure did me in in the hearing department. The biggest concern to look at is where the two halves ocelate, that ring has a tendincy to crack. One thing nice though is I put a air chuck fitting on the treddel valve and used a air powered grease gun and could grease it in half the time.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
Offline Taylortractornut
Re: 1978 Cat 518
« Reply #9 on: September 26, 2011, 05:47:59 PM »
They are tough machines we have a 518 turn around feller buncher and a  Grapple skidder both  we  converted them both to landfill compactors.    The thurn around had a 7000 pound blade instead of a  buncher head.   It runs on rubbish 7 to 10 hours a day.
My overload permit starts after sunset
Offline acco1840
    • facebook
Re: 1978 Cat 518
« Reply #10 on: September 27, 2011, 01:11:38 AM »
I drove a 77 518 cable of my cousin's for 5 years. VERY heavy on fuel if you belt it, but they do compensate with mega power. Gearmatic 19 winch was a bit of a pig, but they are great if you cover them over and dont let them, get wet. Fuel lift pump primer can wear badly...... :'(
Bilzzard Of 1978
Started by Autocar on Forestry and Logging
Last post July 25, 2010, 05:55:48 PM
by woodmills1
1978 clark 664
Started by vatkins on Forestry and Logging
Last post August 14, 2019, 06:52:54 AM
by slakwire
1978 Timberjack 450
Started by Jws_78 on Forestry and Logging
Last post August 27, 2015, 09:02:21 PM
by ehp
1978 mercury 200 20hp
Started by Solo33 on General Board
Last post November 20, 2015, 06:57:17 PM
by Solo33
