Sawing logs longer than your mill?
Started by EZland, February 11, 2017, 09:12:28 AM
EZland
Whats your tricks for sawing logs longer than your mill.  I have a Ezboardwalk jr without an extension  and usually saw alone.
EZ Boardwalk Jr. 30", Husky 455, Kioti 5010 w, FEL , And I just moved to Ohio.and still looking for logs.
God is great!  I will never be as good as the "Carpenter's Son"
LeeB
paul case
At first I thought only on a woodmizer but this video is interesting.
https://www.youtube.com/watch?v=d3ICJ1mqbGE
PC
pc
MobileSawMilSlo
Quote from: EZland on February 11, 2017, 09:12:28 AM
Hi
I recorded one video where I was sawing aprox 30 feet long log.
I hope that you would see how it can be done and how I do it as beginner :)
https://www.youtube.com/watch?v=GE3mg3EfG-Q
Regards
Woodmizer LT20 mobile and TTP-600 Premium Plus
DAJK - all sawing equipment in one place
Ga Mtn Man
LeeB
Must be good. Same one I posted in the first reply.  :D
hopm
Ask a question and get an answer. Just posted this question in a new thread and then found this.
Thanks!!
Peter Drouin
One way.
You can bring the head up while you're cutting to cut the slab off.
Or stop and cut.
You can go all the way around then pull it back and just turn, cut off the rest.
Take it off with John ;D
EZland
Any advise for the opening cut on a manual mill?   Not sure how you would keep the same plane.   After the first cut it would be a lot easier with a flat surface.
Ga Mtn Man
Quote from: LeeB on February 11, 2017, 02:02:27 PM
Sorry Lee...shoulda clicked on your link before posting. :-\
4x4American
On the tutorial that Lee and Paul posted, I don't understand how they get into the cut if they start the cut
with the small end past the operator station.  Unless the log has enough taper which I suspect a long one wood (pun intended).  BUT, if you look at the picture, they're not showing something or explaning it in a way that special people like myself can understand it, because they have the cant sticking out past the operators end, but, it's got 4 faces sawn as far as I can tell.  Maybe too many suds is blocking my vision lol
Boy, back in my day..
   I have read the tip where they discuss, at least with a WM mill, pulling the log forward past the head and the other end such that the saw will pass completely through at the tail end of the log. After making all 4 cuts lift and roll the log forward and cut the other/front end.
   Has anyone done this in reverse where the end of the log is off the tail end of the mill and start the cut from the front? Peter is that what you are showing on your response? That's what I think I am seeing. Looks to me like it would be easier, or at least just as easy, to saw it in that fashion.
   I think this is addressing 4X4's question if I understand his question too.
4x4American
The way Peter illustrates makes perfect sense to me...In the article, I don't get how they dive bomb into the log if the front of the log is past the front of the mill.  Doesn't make a sense to me.  ???
Peter Drouin
There's a bunch of ways to do it. Faster for me to cut all the way around, then pull the log  back.
Ga Mtn Man
4x4...They left a picture out of the sequence but if you read the text carefully it does make sense, although it is a kinda hard to follow.
Peter...What do you do if the uncut end is too long and ends up sitting on a bunk?
slider
Customsawyer taught me to saw up out of the cut before you get to the end with the head moving.I also use an extra roller table to support the log.If you have roller toe boards it is easier.
al glenn
Dave Shepard
I do it the same as Peter for anything over 45'.
For longer stuff I add another BX. 57' capacity, 52' log:
Kbeitz
I made a fast attach extension for my mill. 5 bolts and it's off.
The orange part is the extension. I have a set of new jacks to
put under it. It's much easier than fighting a long log.
Love machine shop work
and Wood work shop work
And now a saw mill work
4x4American
Kbeitz
Quote from: 4x4American on February 12, 2017, 12:42:01 PM
Did ya run out of blue paint?  :D
Yes I sure did... i bought two gallons of discontinued  paint cheap
and thought i was getting a good deal at $5.00 a gallon. it took all
of the two gallons to paint the mill and i had none left over. Now
I can't buy the same color to match.
Brucer
Quote from: WV Sawmiller on February 11, 2017, 08:45:09 PM
... Has anyone done this in reverse where the end of the log is off the tail end of the mill and start the cut from the front? ...
Yes. It's the only way I cut over-length logs.
Quote from: EZland on February 11, 2017, 06:56:49 PM
I've done it on a manual mill. You need to be able to shift the partly cut log lengthwise on your mill. I used the hook (of an old-style peavey) attached to a come-along.
Keeping the same plane is key. One guy I know made a cradle out of lumber that supported the log. He would slide the entire cradle along the mill. That's a pretty slow way to do it. My method was to cut as far as I could (just a Peter does), then roll the log to get the flat side down. Saw the second face as far as possible, then slide the log (on the flat face) and finish the cut. Go back and deal with the original face later.
As you said, once you've got a flat face the length of the log, it's pretty straight forward.
Quote from: Ga Mtn Man on February 12, 2017, 07:42:01 AM
The basic Wood-Mizer frame has close to 6' of cutting room past the furthest bunk (as long as you swing the movable bunk out of the way). I didn't have this room on my mill with two 6 foot extensions on the end. There's only a few inches of cutting room past the last bunk on the short extensions.
My method was to have a set of 3 wooden spacers on hand, which I could place between a bunk and the flat of the log. One spacer as close to the uncut end as possible, one as close to the sawn end as possible, and one in the middle. That worked well on my hydraulic mill with roller toeboards to move and lift the log while I set the spacers.
I've also seen a guy cut two long spacers that ran lengthwise down the log. He didn't have roller toeboards so this allowed him to slide the log and the spacers down the mill.
For really long logs I always have some method of supporting the overhanging ends of the log or cant. It's surprising how much a green log or timber will sag under its own weight. And even though the saw won't be cutting the overhanging part, if the overhang is too long it can bow up the centre of the cant.
Bruce    LT40HDG28 bandsaw
Nomad
     I'm the guy who made the cradle.  The way everybody else does it works great if you're cutting a beam from a log.  But if you need boards the full length of the timber it'll only work after you've got the first side flat for a reference.  And in this case, I was resawing old timbers.  Only one cut each.  So the cut had to go the full length and had to stay flat.
     It was rather slow, but the results justified the time involved.
https://forestryforum.com/board/index.php/topic,93458.msg1439766.html#msg1439766
WoodMizer LT50HDD51-WR
Lucas DSM23-19
4x4American
Quote from: Kbeitz on February 12, 2017, 12:48:55 PM
I figured it was either that or to make it easier to find when it's buried under the snow or off in the dingle weeds
Joe Hillmann
Quote from: Kbeitz on February 12, 2017, 12:39:12 PM
Is the cable on the right side for your powerfeed?  If so, how do you make it work with the extension being removable?
Kbeitz
I have two eye hooks. One on the end of the extension and one 13 feet
back on the main part of the mill. When I take the extension off I unhook
the cable and loop it around a cam and back to the eye bolt that 12 feet
in on the mill. Works great. The cable has a turnbuckle on it's end.
Deese
I've got to saw 80 4x8's for a customer. Twenty of them have to be 24' long.
I've got 2 options. One is that I could take the long boys to the guy who bought my manual mill, which can saw up to...nevermind! Dang! While typing this, I was thinking my old mill could saw 24', but it only saws 22'.
So I'll be sawing them on my LT40. Now I've just got to decide on which sawing style I will use. The way Peter Drouin and Dave Shepard do it, or the method shown in the knowledge base link on the home page.
I'm thinking the way Drouin/Shepard does it will be a little faster. I could use one of my smaller chainsaws and just make sure not to scar the beam surface on the last cut...leaving just enough "meat" not to scar the beam and then just "tear" the board away.
OR I could use a circular saw to make clean, measured cuts. Both Dave and Peter's photos show that a circular saw would work as long as you make each cut a little shorter than the previous cut. That way, you've got a flat surface for the circular saw depth gauge to rest on.
To me, it makes better sense to put the BIGGER end of the log facing the front of the mill if using this method, right? This would reduce the number of cuts with the circular saw at the opposite end of the log, thus saving more time.
Step #1: Put the log on the mill with big end at the front.
Step #2: Use rear toeboards to level the pith.
Step #3: If there is a lot of taper, then your first few cuts may not make it all the way to the end of the frame. Keep dropping with
              each cut until you saw all the way to the end of the frame. Disingage blade, back out of the cut a few inches.
Step #4: With circular saw (I want to say "skill saw" so bad), adjust cutting depth to the same or slightly less than your board
              thickness and cut off first slab.
Step #5: Return saw head all the way to the front of the mill, rotate log 90°. Then repeat steps 2,3,and 4.
Step #6: Rotate log 90°. This is your 3rd face opening. Make sure the toeboards are all the way down. The bottom flat surface of
              the log should be in full contact with all of the sawmill bunks if your mill is sawing correctly and there isn't significant
              stress in the log. Repeat steps 3,4, and 5.
Step #7: Repeat step #6. This is your 4th face opening. Once this step is completed, you have a cant that may or may not have
              rounded edges at this point.
Step #8: Saw the cant to the dimensions you prefer by repeating steps 3-7 and keep toeboards down this entire time.  While doing
              so, make sure to follow the cathedral grain pattern and make adjustments to keep the pith as close to center of the beam
              as possible.
Step #9: Once the beam is sawn to specifications, raise toeboards and push log toward front of the sawmill until the blade is able to
              exit the end of the log. Be sure that log is positioned where the uncut portion of the log does not contact the end bunks.
              Lower toeboards and secure cant with clamp.
Step #10: Set blade to height of beam surface and finish cutting the beam by making cuts and rotating log.
I'm in a big hurry trying to finish this thing up, and I'm sure I've probably made some mistakes (maybe big ones)...I'll read it over when I get settled at home.  What do you guys think?  Basically, I'm trying to generate some conversation about doing this, what and what not to do, etc. Because I have no choice but to make this happen very soon.
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Ga Mtn Man
First I would refer you to this thread as a warning:
https://forestryforum.com/board/index.php/topic,95523.0.html
That was my first foray into sawing over-length logs and I think I tried just about every log position possible.  I decided I preferred to have the butt end at the front of the mill, as you said.  This leaves less weight hanging off the rear of the mill making the log less likely to bend from its own weight and it won't tip as you move it back and forth on the toe rollers.  The downside to doing it this way is you have a smaller target to hit hanging off the end of the mill.  You will find out in a hurry that there are very few truly straight logs out there.
Peter Drouin
There's a bunch of ways of doing that.
Cut up out of the cut. Or cut with a chain saw. Mark how far the blade will go down the log. cut down with your chain saw, not too far and cut to the saw cut.
You can use a flat bar and lift the 1" board you just cut and slide a 1x4 down the cant as far as you can and cut on top of that with your chain saw.
The log in the pic has the big end to the front.
I did not plain that , I cut all my logs here the way they come, big end or small first I don't care. :D
