Author Topic: Taxing the limits  (Read 817 times)
Offline Percy
  • Resident trouble maker
Taxing the limits
« on: May 22, 2016, 12:08:20 PM »
I had to cut  a bunch of 12x12x12 sitka spruce curbing for a logging bridge...12x12s outof 22 inch logs makes for much side lumber that will probably be the wrong size for the next customer....so I went to the "big" log pile....30 inch plus...and made the 12x12s, 4 pieces at a time....
There is only so much room on the LT70 throat.
Making them 4 at a time is fast.....if you dont get hung up. My door latch thingies were rubbing on the cant...but...see next pic
Wane is my new friend.....normally I dont like visits from him....but the log trucks arnt gonna mind....and a good bridge builder will hide my new buddy  ;D ;D
Offline ladylake
Re: Taxing the limits
« Reply #1 on: May 22, 2016, 04:09:43 PM »
 I thought a LT 70 had more capacity than that, are the newer ones bigger.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Percy
« Reply #2 on: May 22, 2016, 04:19:06 PM »
The newer wide heads are. This unit is 13 years old   ;D
Offline starmac
« Reply #3 on: May 22, 2016, 05:20:36 PM »
This is probably a stupid question, and I know the grain is straighter in sitka spruce.
Does it not hurt to split the pith in sitka spruce when making thae bigger beams?
Everything I have read has called for boxing the heart for beams, but don't see much concerning spruce, especially sitka.
Offline Percy
« Reply #4 on: May 22, 2016, 06:25:33 PM »
Not a stupid question by any means. These timbers are being used for bridge curbing. They are drilled and bolted down with big 1 inch bolts. They are replaced every 5 years or so due to grader damage, rot, etc.  At 12 feet in length, if they do bow, it is minimal as they are 12 inches x12 inches. . If I were cutting for a timber framer, I would do things differently.
off limits to you
Started by treeslayer2003 on Technical Support Topics
Last post May 31, 2015, 04:27:17 PM
by treeslayer2003
I met the limits of my education
Started by underdog on General Board
Last post March 25, 2009, 04:10:16 PM
by scgargoyle
testing my limits
Started by Dave H. on Sawmills and Milling
Last post March 09, 2016, 10:03:28 AM
by Percy
Rules For Weight Limits ?
Started by Autocar on Forestry and Logging
Last post July 04, 2011, 03:13:22 PM
by smwwoody
