Wood Mizer BMST50 changing CBN wheel
Started by DarlaL, October 18, 2022, 04:09:29 PM
DarlaL
We have a WoodMizer BMST50 sharpener/ toothsetter. How does everybody change the CBN wheel? I was able to change it once, but I am unable to remove it now. I can't find a lock button to lock the wheel while loosening the nut. I think I tightened it too much haha. When I changed it the last time, I used a small flat screwdriver and held it in the set screw hole behind the wheel. Nothing else fits in there, and this time, the screwdriver won't hold up to the pressure. I called WoodMizer and they are contacting the Head Technician in Ontario. In the meantime, they recommended an impact driver. I'm afraid it might hurt something in the motor or on the spline. How do others hold the wheel still in order to remove that nut? I won't use vice grips or anything of the sort in case I damage the wheel.
Any help would be appreciated!
SMG Champion Portable Sawmill - BMST50 sharpener/toothsetter
terrifictimbersllc
On my BMS 250 I just hold the wheel with the heel of my hand while I turn the nut with a wrench. I could also imagine arranging a tapered wooden block to press in against the wheel if I needed more force than that. Not pressing on the side of the wheel, but on its circumference. If you can't do it by hand you might consider holding the wheel firmly as you can with your hand and then gently using an impact wrench to loosen the nut. It doesn't take much torque to tighten the nut so that the wheel won't move.
DarlaL
Wooden wedge is a great idea! Thank you. I tried the heel of my hand but just about burnt it when my husband cranked on the nut  :D
I will try it and let you know. Thank you very much!
Ljohnsaw
It's not a left handed thread by any chance? ::)
John Sawicky
Stephen1
No LJ not a left hand thread. I thought so when I 1st got my sharpener, as I had lots of trouble changing the wheel, I also tightened too much. Also I ended up using some emery cloth on the spindle as the grinding wheels would not easily come off. Now they slide on and off no problem. Also I just snug it up holding the wheel by hand.
DariaL, Another fix if that doesn't work is an oil change filter wrench around the wheel.
DarlaL
Quote from: ljohnsaw on October 19, 2022, 10:09:56 AM
No. We thought it should have been, but it's not.
DarlaL
Quote from: Stephen1 on October 19, 2022, 11:38:16 AM
The hardwood wedge worked! And surprisingly enough, I was looking in the bottom drawer of my husbands tool cabinet and staring at the rubber filter wrench and then got distracted! Thanks everybody for the great ideas. I was told by the guy at WoodMizer that I was the only one he knew of that had had that problem. Thanks for letting me know I'm not alone ;) haha
