harvesting knots
Started by mrbrb, October 16, 2013, 03:05:05 AM
Ken
mrbrb
Very nice looking projects.  Hats off to you.
LeeB
Wow, some drill bit you got there. Did you make it yourself?
Okay, do I have to be the first to ask about the giant duck on a pallet?
Maybe it went to Wilton ME. I think there are a few around town like that. They are all diffeant painted.
mrbrb
thanks for the kind words-
regarding the drill bit, it is just a standard 1" metal cutting bit, welded to a 9' piece of rod. Figuring out how to drill that 9' hole straight took a lot of trial and error. Barefoot auger wandered way too much. Step bit was straight but slow. With this metal cutting bit, it took about 20 minutes per 9' hole.
regarding the duck, it is carved from a block of brownstone.
so now that I've got about 400 knots, need to figure out how to dry them without too much warping.
Thanks for all of the suggestions.
That was quick.
From last evening to this morning, you now have a bucket with 400 knots.
From where did you collect them? They look to be about 1/4" thick.
Cedarman
Looks like you made a lot of knot holes.
jueston
I can't believe how centered that hole was after 9 feet.... wow...
Likely staying in the soft juvenile core wood at the pith center is not that much of a problem if started right.
I'd think plugging up the bit with drilled wood means several withdrawals to clean it out.
That is quite an indexing rig used to make the different face cuts. Leaves some slabs that might be reassembled into some other form of art, but I don't know what it would be..   ;D
RynSmith
Quote from: beenthere on October 17, 2013, 02:24:01 PM
We should hook up mrbrb with that artist (I think she was a she) who was looking for slabs not too long ago!  ;D
Roxie
Quote from: Jeff on October 17, 2013, 08:22:45 AM
That is one really awesome duck!!
Say when
You certainly have some very interesting projects and ideas mrbrb, and Welcome to the Forestry Forum.
I do not know how to harvest knotholes, but my company name is Knothole Sawmill.   :D
