LT15 Needs New Engine
Started by firefighter ontheside, December 18, 2020, 01:43:56 PM
Well, my 15 horse Kohler bit the dust today.  At least I think it did.  Looked at the valves and they look fine.  Turning the saw manually wiht the spark plug out it turns and then catches, turns and then catches.  It still seems to have compression.  I'm not sure if its the rings or what.  I did restart it after it died.  It would run, but sounded like there were rocks in there.
I'm expecting to replace the engine.  Woodmizer has a new engine kit to go from 15 horse to 18 and parts needed to retrofit.  That is $2250.  I'm interested in ordering a new engine locally and mounting it.  I'm waiting to hear back from my local small engine shop to see what they find.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
SawyerTed
That's not good news but it does allow the chance to bump the hp a bit.  I'm a believer in going with a replacement engine manufacturer that you can get support, parts and repairs for locally.
FWIW, I tried one of those Chinese engines on a wood splitter once.  It ran and operated well for two years then it went to the recycling bin.  I couldn't get replacement parts.
The aggravation of uninstalling the old, getting a new one and reinstalling the new engine would have been worth the extra cost of going with a brand name.
btulloh
Bummer. Engine failure is not usually something we wish for but it happens. The silver lining in that cloud is the opportunity to get more hp.  And a lighter wallet.
I hear Santa is a good source for small engines.  :)  Just send him an email and the new engine will be under your tree. (How wide is the flu in your chimney?). ;)
HM126
I just talked to Santa(she goes by Cindy in this house) and she said thats too bad.  I guess you need to buy a new motor.  At least its tax deductible.  I am looking forward to more HP.  Just hope its not too difficult to mount a new motor.  Seems like the biggest concern is making sure the output shaft lines up with the drive pulley.  The other concern would be the throttle linkage, lining it up so that when I engage the blade it also engages the throttle.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
SawyerTed
Yep, Santa goes by Emily here.  I don't know what I'd do if she weren't raised on this farm.  She understands equipment repair expenses.
Haleiwa
When my Onan died, I bought the Kohler engine, the mounting adapters, and the new belts from Woodmizer for less than an engine alone was going to cost from the other suppliers that I checked.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
pineywoods
Don't know about the lt15 but probably easy to do an engine swap. I went from an 18 hp briggs to a 25 hp liquid cooled kawasaki on my lt40, back sawing next day. Most important thing is weight. Too much and have to upgrade the head lift mechanism.
Well, I just removed the engine and it was super easy.  4 bolts and 2 wires removed and its off.  Won't hear back about an engine til monday.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Southside
What about going to a diesel?
White Oak Meadows
doc henderson
so Bill, are you on the nice list... or the naughty with @Southside ?   :) :) :) :snowball: :christmas: :snowfight1:
Quote from: Southside on December 18, 2020, 04:03:17 PM
I love me a diesel, but I think it would be too heavy.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Walnut Beast
I see they offer a 10hp and 17hp diesel for your mill .
Southside
Doc - if it weren't for guys like me trying so hard to be on the naughty list - you wouldn't look so good.... :D
White Oak Meadows
They do offer diesel on new LT15s, but they don't offer them as a refit for my 15 year old mill.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
sawguy21
Do you put enough hours on the mill to justify the extra cost of a diesel? Then there is added weight. Swapping in another Kohler would be easiest, also have a look at Honda and Briggs Vanguard. Stay away from the cheap off shore clones unless you are willing to sacrifice long service life to save a few bucks.
mike_belben
Why didnt you tear the motor down?  Its not like youd have made it any worse.
Praise The Lord
Durf700
are you able to go to the 25 HP Kohler that comes on the LT 35?  the newer LT 15s are 19 hp I think.  I would definitely ask what your options are.  what year is your mill?
I did remove the valve cover and see that the valves look fine.  Looking in thru the exhaust port I can't see anything out of order.  Turning the drive pulley over by hand with the spark plug out it turns easily and then theres resistance.  Have to force past the resistance each time I turn it.  I have the engine off and may take to the shop on Tuesday.
My mill is an 04.  The replacement engine that WM offers is an 18 horse Kohler. I'm going to see what the small engine shop can offer me.  I don't think I will seriously consider a diesel.  I'm assuming any engine thats heavier will make it more difficult to raise the saw.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Resonator
15 years is a good run for a small engine, maybe it just wore out. I was told the Kohler G18 and G19 are basically the same engine, and I have had good results with the G19 on my Lt28 for the last 3 years, adequate power for a manual mill. Only thing it did not come with an hour meter, would be good to have to keep track of maintenance.
Yeah, that's why I'm a little skeptical about putting any money into repairing it.  I bet my engine shop that I take my other small engines to could fix it, but I'd rather put the money into a new/upgraded engine.  I have been a little confused by the 18 and 19 horse engines.  I was searching around and came across the engines on northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company site.  Nowhere in the description does it say how many horses they are.  They have what appear to be 2 identical engines about $250 difference, but can't really tell what the difference is physically.  Woodmizer uses the 19 horse on new mills, but offer the 18 as the upgrade.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
sawguy21
Horsepower ratings are pretty loose, generally whatever the OEM wamts to see. The 18 and 19 horse engines are basically the same except for decals although one may have improved filtration and low oil shutdown.
RichTired
Resonator, I installed an inexpensive (less than $10) hour-meter on my LT15 I got from Amazon.
Link
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 & Stihl 241 C-M chainsaws, Logrite cant hook, Ford F-150 Fx4
Richard
richhiway
Just curious, do you know how many hours is on it? Take the cover off the flywheel it may have something wrong there, it may not be a internal engine part.
I would go with the Wood-Mizer up grade. Should be flawless. I would not expect a lot of difference, small engine horsepower ratings are suspect.
While you can repair small engines they are not "rebuildable"like the engine in a tractor,etc. Don't spend much repairing it at 15 years old.
Good Luck!
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
doc henderson
if it sounds like gravel, but runs, could it be a connecting rod bearing?  i once thought the from crank bearing went out of my camero.  1974.  a bolt had came out of the and harmonic balancer?  anyway it threw all the belts, and would run, but looked like the fromt of the crank was wallowed out and not turning concentrically.  new rubber and bolts
Doc, a guy who works for me here is a car engine guy and he said the same thing.  Might be a crank shaft bearing.  I think I'm gonna ask the place where I would have it repaired if they can diagnose it for no charge as long as I either pay them to repair it or buy new from them.  The motor has always ran great for me.  The only problem I ever have is that the automatic choke doesn't work so I have to reach up inside under the carburetor and move it by hand.  Annoying, but not a big deal.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
