Kiln Intake and Exaust Vent Instillation Question
Started by Ga_Boy, August 21, 2005, 05:57:01 PM
Ga_Boy
I'm just about ready to cut the vent holes in my kiln chamber, which is a 20' insulated sea container.
The exterior is Aluminum with about 4" of foam insulation, the interior is stainless steel.
Now, here is my question.  When cutting the holes for the fan and exhaust vent, should I install a header to bridge the opening?
I have assumed I will cut through some of the structural studs in the wall of the container.
Anybody got any suggestions on this one?
Dan_Shade
Hey Mark,
are there studs in there?  are they wood, or those metal reinforcement ones?  I think I'd certainly do something, easier to do it and avoid a problem than wish you had later.
It may not make much difference, but it could help the wall with wind loading and such.
Dan
lots of dull bands and chains
GaS
I was wondering how you were doing on the project!
The fan didn't vibrate too much that I noticed, but over time you never know.  Reinforcing it isn't a bad idea if you have material handy.  Having not seen a cut-open sea container, I can't say for sure, but I imagine they are extremely well-built pieces of equipment.  Translation: you probably don't need to but overkill doesn't hurt :)
G
Den Socling
I'd add headers to keep moisture from getting between the two skins even if they weren't needed for structural integrity.
