Author Topic: Oh, how a project grows  (Read 851 times)
Offline boonesyard
  • I've got a little sawdust in my pocket
« on: October 18, 2021, 11:32:24 AM »
It started with a customer building a new hunting cabin that began last year. He had to cut a couple large bur oaks down and had us saw and dry everything in to 4/4 for base and trim. There were a couple larger logs that would make some decent slabs so we sawed them up, just in case. Let everything air dry for a year, kilned it all this year and got the trim to him this summer. He was pleased with it and asked if we had enough material to build his interior doors, we did. I laminated 2 pieces of 4/4 for the rails and stiles, and milled them down to 1-3/8". The panels are a simple V tongue and groove.
He liked the doors so well, he asked if we could build him a table. I just happened to have enough 10/4 for the top, so that's next. He wanted a fairly heavy look and we didn't have enough 10/4 for the legs, but had a lot of 4/4 left. He let me run with the design, so it'll be bar height and a trestle style base.
Top
Parts to laminate the leg components and the stretchers
The first trestle leg dry fit
Need to cut the mortise in the upright yet, but pleased with the result. Got some work to do to get it finished and delivered by the first weekend of November, deer huntin ya know.
We've kept him in the loop during the process, and now he would like us to build him a timber frame loft. The cabin sidewalls are 16' so it's doable. We'll need to process more material for the loft build over the next year. Funny how a small project can grow  8).
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline firefighter ontheside
  • I like trees.
Re: Oh, how a project grows
« Reply #1 on: October 18, 2021, 07:45:28 PM »
This is a very nice, large project.  love the doors.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline VB-Milling
  • Always learning
« Reply #2 on: October 19, 2021, 09:30:52 AM »
Those are some handsome looking doors!  Looking forward to seeing the table top on the base.  I like the angles.
Interesting the owner chose such a tall baseboard profile with such a narrow door casing. ???
HM126
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: October 19, 2021, 10:12:47 AM »
Love the door too.  Well done!
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline samandothers
« Reply #4 on: October 20, 2021, 10:59:19 AM »
Obviously you do great work!  It shows and the owner is pleased and likes the idea that it is getting done versus taking forever.  The doors do look nice and the table is shaping up to a great piece!
Thanks for sharing this.
Offline boonesyard
« Reply #5 on: October 21, 2021, 11:54:14 AM »
They ended up using the larger base to cover up the 8" block that was used for a ledger.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline barbender
« Reply #6 on: October 21, 2021, 06:15:05 PM »
Wow, just wow! Not only is the work beautiful, but bur oak is one of my favorites!
Offline boonesyard
« Reply #7 on: October 22, 2021, 08:37:39 AM »
Thanks barbender.  I really like bur oak too. If you can get it sawed and dried flat, and no honeycomb, the character is beautiful.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline metalspinner
« Reply #8 on: October 24, 2021, 08:44:34 AM »
The owner is going to love telling the story how the logs on the property were used in the cabin. Every new visitor to the cabin will hear it.
Offline boonesyard
« Reply #9 on: November 05, 2021, 10:20:01 AM »
We completed the table last night, will wrap and load this afternoon and delivery this evening. Deer hunting starts tomorrow, so we'll call this just-in-time  ;D
The owner wanted and heavy, natural looking European bar height pub style table. I sure hope he likes it.
It's 42"W x 96"L x 41"H. It's finished with 2 coats of Rubio Monocoat and Blackforest Wood Co Ceramic coating. We've used this system for a number of projects and it holds up VERY well to abuse. All table top voids are epoxy filled.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline aigheadish
  • Tiiiiimmbeeerrr!
« Reply #10 on: November 05, 2021, 10:40:33 AM »
That's really lovely!
Is it still in the neighborhood of 10/4? It doesn't seem that thick. Is the top attached to the base somehow or just gravity?
Offline boonesyard
« Reply #11 on: November 05, 2021, 10:56:27 AM »
Thank-you.
By the time all of the milling and flattening took place, the top is 8/4 finished. The table actually comes apart and can be moved/transported in 6 separate pieces. The two trestle ends, two top stretchers, the heavy bottom stretcher and the top. The two top stretchers are connected to the trestle ends using Rampa connectors and bolts. The bottom stretcher is obviously a thru mortise and tenon with wedged tusks and the top is then connected to the top stretchers using Rampa connectors as well. Very solid.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline WDH
  • Forester
« Reply #12 on: November 05, 2021, 11:43:28 AM »
That is very well done, Sir.  Very well done.
Offline Nebraska
« Reply #13 on: November 07, 2021, 11:01:51 PM »
Nice!
poplar project continues and grows
Started by hopm on General Board
Last post July 19, 2019, 12:31:56 PM
by Autocar
grows 292 bft,Ac
Started by Rod on General Board
Last post February 14, 2002, 06:41:46 PM
by Tarm
NE Grows show
Started by woodmills1 on General Board
Last post February 08, 2007, 10:46:17 PM
by woodmills1
moved
MOVED: Marijuana Grows
Last post January 06, 2014, 04:08:05 PM
by Jeff
