log furniture
Started by 4woody, January 18, 2007, 10:35:39 PM
4woody
i know someone who wants to buy one of my benches and i was wanting to know how much to ask for it. the bull dog was drawed by hand and burnt into the wood
Brad_S.
I don't have any idea what it should bring, but I wanted to reaffirm to you to not sell too cheap. That's a real nice piece! Too often us part time woodworkers under value our time and talent. Don't let that happen on this piece!
If it were me, I would add up the time I spent on it plus material and put an hourly rate on my time. ($25? hr.) I suspect you will be taken back by what it totals, but then it's up to you how low to go on your rate.
Good luck.
metalspinner
The cost of things  I make are directly attributed to my desire to make them. ::)
No, really...  You need to balance the time you have invested plus materials to the market value.  If you get really good and fast at making something, don't penalize yourself on the time side.  The time of gathering materials in the field should also be considered - not just your shop time.  Then you have the asthetic value and uniqueness to consider.  Did this person ask you, or did you approach them.  Your in a better position , of course , if they approached you.
I used to ask my wife the same type of pricing question all the time.  Every time I was disappointed in her answer. ::)
Wait, I just thought of a great idea!  Donate one to the Forestry Forum for an auction and use that price as a benchmark. :D :D Ask me how many birdhouse ornaments I've sold for $187. :D :D :D
Something else to consider...If you under price the work because you are not a "professional" that could adversly effect the "real" professional trying to earn a living.  If the market is saturated with "non-professional" underpriced work - even top quality like yours, then the paying public will expect low pricing on all craft objects. IMHO
4woody
it took my wife about 2 hours to draw it and burn it in the wood and  it took me about 3 hours to make it and sand it and then puting on the clear coat i'm not sur how long it took on that what would yall recommend for a finish
TexasTimbers
Brad summed it up pretty well. I know you probably want to see some guestimates but it is hard without knowing how proficient you are; how long it took. If it took you eight hours total then you'r near around $300 because you have materials. When I say eight hours I don't just mean the time you spent working on it, you have the figure the time it took to chasing all the materials. Looks like log legs. Did you get in your truck and burn diesel to burn some 40:1 mix to cut those logs? Ya gotta figure all that.
On the other side of the coin, if you are happy to pay someone to take it and it truly makes you happy then that's your business. Bad business of course, but yours.  :)
TexasTimbers
Sorry woody I was typin while you posted. Yep I am that slow sometimes. I will let the finish experts answer your finish question, but I am a recent lacquer convert. It's not good for everything but it's pretty fool proof and sure does shine. MAybve an oil would be better though for a seat. But like I said I will leave it to the finish experts.
4woody
metalspinner how can we donate one to forestry forum we would like that verry much because everyone here has been so nice and helpful
4woody
for a finish we put 2 coats of linseed oil and 2 coats of polyurethane
Brad_S.
Quote from: 4woody on January 18, 2007, 11:26:08 PM
PM Jeff. I'm sure he'd be very grateful!
4woody
oky i pm Jeff so lets see how long it takes a busy man to reyply oh for the legs my boy an i took a light an hand saw to the woods at night cut from a fallen tree
solodan
Woody,
you know what your time is worth. Don't sell yourself short. On the other hand it is sometimes ok to take a smaller profit if it is an influential customer. I have gave deals to contractors that build custom homes, lumber distributors, people with ties to major publications, and that kind of stuff. I don't know how much it helps, but I have got  referals this way, and it definately doesn't hurt.  Eventually as one becomes more busy we go back to point #1, what is your time worth? well more than it was when you started. which to some degree creates more demand from the higher end customer, which results in more demand all the way across the board. 8) As long as you are honest and fair, I believe you will prosper. :) at least that's what I counting on. ;)
metalspinner
It sounds like you're reluctant to charge what you think you are worth.  Don't feel guilty about your price.  If you honestly think the stool cost xxx amount of time and you charge $xx  per hour, then that's the cost.
If you think you were not very efficient because that was the first one, then make a batch of three or four, average in the first one and that will give you a good base.  You do owe it to your customer's to work efficiently.
Things like the drawing can be added as an option to the customer if they think the stool is to high.
A couple coats of poly is plenty for the finish.  I haven't gotten into spraying yet, but pre-catalized lacquer seems to be on everything now a day's.
4woody
I was thinking about trying to do some spraying on some of them an i was thinking this woud be a good place for every one to show there stuff
4woody
Will i started the one for the forestry from so far i have 3 hours  on it an still haf to sand it an then it will be ready for my wife to do her part
4woody
A questuen would you leave the bark on the legs or take it off ?
Stephen1
I make some Log benches with no carvings on them. The top is scribed to logs underneath, then drilled,  bolted together with 3\8 threaded rod. then pluged from the top.
I am having troubles with the dowling starting to break on some, and am looking into have some steel bent to replace the wood dowling.  I did not  sand this group , because they are rough from the chain saw, they use approx. 1 gallon of Cabot Stain. I have been charging $200 Canadian. When I built them I figured on 4 hrs of labour $100, wood$25, $50 for stain, then a little extra for everything else.
   I have built anouther group and sanded them, nicer looking now that they are sanded then would like to apply a shiney type of finnish, I believe I will get $300. As soon as it warms up and I can walk I will finnish them and post some photo's.
Quote from: 4woody on January 20, 2007, 08:48:22 PM
4woody
      I believe the bark will eventually fall of as the wood shrinks.
4woody
That is a nice dawg, 4woody (nice bench too  :D).  Benches take a lot of abuse and wear, so the poly is a good choice.  One reason lacquer is so popular is that it dries very fast, so multiple coats can be applied in a day.  That is why the cabinet makers and other high production shops use it so much.  For someone like me who does one project at a time, multiple coats in a day is not critical.  Also to safely spray lacquer, you need a spray booth with fans, etc.  I would say stick to the poly or an old fashion alykd varnish.  They both work well with oil, so you can use an oil base like dansih oil or tung oil and topcoat when dry with poly or varnish for protection.  Looks great too.
4woody
Thank you WDH for your coments i like the rustick stuff i wuod like to see what other people have to show to
4woody
this is a few pic's of a new log bench we are working on. It tock my wife 2or 3 hours to draw and burn it free handed. but shes not sure she likes it so we mite sand it off and start over.what do you think.  :-\
Norm
It looks great the way it is 4woody, what kind of wood did you use?
Murf
I agree with not selling yourself short.
I posted a whaile back about some shelves I saw while on the left coast visiting family and taking a much needed break.
Now I realize, they were being sold in an "artisans co-operative" store, (read: extra $50 for being artsy-fartsy) and in a very toutisty area (read: another $50 just cause they can)  but still.......  these shelves were selling for $175 each!!  :o
When I jokingly said to the young feller working there, "I'd need lots of them to fill my wall..... do you have many left in stock?" he never missed a beat and came back with "I'd have to check, we sell several a day some days."
I nearly fell over........  :o
I figure there's about $0.50 worth of varathane and a $10.00 piece of glass in there, short of that, just some scrap slabs and a few cuts.... even I could do that!!!
4woody
norm its white oak and thank you
murf we ant going to sell none until we know what to sell them for. because some take longer to make then others
solodan
This style brings me between $300-$400
I like those shelves, especially the price, maybe I'll do some of those. ;)
I went into a store near here that had 18" stumps for sale It was just a 12" firewood round, sanded and finished.  $125 :D  They told me that they sold 3 of them the first day. ::) :D 8)
4woody
Hay solodan what kind of wood do yuo use i make some like that to looks good i like to see every budys stuff to thank you
