Author Topic: 14" rough sawn pine flooring  (Read 4463 times)
Offline shinnlinger
Re: 14" rough sawn pine flooring
« Reply #20 on: January 03, 2016, 07:40:26 AM »
This is the updated thread I mentioned before... https://forestryforum.com/board/index.php/topic,87730.0.html
Shinnlinger
Offline kantuckid
« Reply #21 on: January 03, 2016, 09:02:37 AM »
I did a couple of porch floors in Red Cedar heartwood using 1x6 boards. I planed the bad side to equalize thickness, jointed one edge, table sawed the other and lightly orbital sanded the good face with 180 grit while also beveling the edges ~ 3/16" with the sander. I used SS screws and some clamping to apply it with an oil finish. The band sawed but with light sanding surface goes well with my log house for a usefully smooth finish yet rustic enough.
Inside my home I have wide oak that was nailed through a countersunk hole and plugged with walnut-now days I'd certainly use either plugged screws or Tremont handcut nails-if a pine floor. Oak they would split unless pilot drilled.
I used Waterlox brand of varnish on my most recent wide board oak floor in a timber frame room addition. that floor is T&G. That varnish is the best varnish I've ever used-period! Several choices in their lineup and can be found sold by some hardware chains at a discounted price if you buy a case of 4.
I'm planning another small cabin for guest/hunters use and may go with poplar. In my area a mill has been selling poplar for flooring, ceilings,walls for a few years now in 1x6 T&G. If you go wider then gaps will happen even in KD. I'll do my own wood and air dried in my cabin and probably go wider.
In my home I have all open ceilings which are T&G 8/4 pine. I paid a mill to run the old part of the house from air dried WP but the new room has my own version run on my router table. i found a builder that liked western WP and bought part of a bundle from him so KD. SPF also looks decent to and you can just buy from a regular lumber building source in KD. I drew up my own set of cutters after not finding what i wanted already to use and saved much money by milling my own T&G wood. In a rustic cabin it could be the finish floor too. Might lightly break the top edges for splinter free floor.
The Op's floor looks nice but stains don't appeal to me much, just a personal wood thing. I'd wash with sodium percarbonate or similar non toxic wash, then do the drying thing. With eastern WP your likely to have some blue stains either way though. Mills dip their bundles to avoid staining.
wide plank rough sawn flooring over radiant
Started by MReinemann on General Woodworking
Last post March 19, 2013, 05:46:20 PM
by tyb525
(20) rough sawn 6"x1"x120" Stone Mountain GA
Started by rebocardo on Wanted
Last post April 13, 2011, 10:09:34 AM
by ATLGA
rough sawn green pine table question...
Started by zelpatsmot on Timber Framing/Log construction
Last post March 06, 2019, 09:01:32 PM
by rjwoelk
Pricing Rough Sawn Pine for Board and Batten?
Started by rasman57 on Sawmills and Milling
Last post April 18, 2020, 03:33:26 PM
by Bruno of NH
