What to do with this Echo 610?
Started by lledwod, November 09, 2015, 10:14:10 PM
lledwod
I purchased this saw recently for 100$. It will not turn over, it is missing a coil, and one half of the crank case is broken :o   So I started digging into it, and find that inside the cylinder and crankcase is terribly corroded. White grey dusty/pasty stuff. The corrosion has 'delaminated the chrome liner from the one cylinder.
So .... I understand it may be difficult to impossible to get parts for this? I would say minimum it will need a cylinder and a coil. With these two pieces it just might be possible to get it back running. If I can't find a cylinder is this worth selling as a parts saw?
Thanks for any help or ideas! I sure would like to hear it run!
lledwod
It was all in one piece with bar and chain when I got it, I should have taken a photo before I started into it.
starmac
I have to ask, what would it be worth running and in good shape, no broken pieces.
I have trashed saws ib better shape, but they would have been worth parting out if a guy wanted to fool with it.
dougand3
You got that saw real clean looking. But that crankshaft is dang ugly. I'd part it out on ebay - bet you'll make more than your money back.
