woodmizer lt 28 whine under load
Started by NPsawyer, October 28, 2016, 10:08:36 PM
NPsawyer
Since this is my first post, I suppose I should introduce myself. My name is John Stapleton. This past summer I purchased a woodmizer lt 28 and now have around 20 hours on it. What a great feeling taking logs and making them into my future quartersawn red oak floors 8). My problem started recently and consists of this:  my mill will make a whining noise; especially towards the middle of the cut when under a "heavy" load. I have set the drive tension to specs (14lbs at 7/16 deflection) and checked it several times. I found a loose brake pad and tightened that back down and adjusted it. That seemed to help for 100bf? but now the noise is back. It only makes this noise on wider cuts >1ft. When I put a fresh 4 degree blade on it saws sweet as can be noise free for several cuts but then the noise returns. The mill cuts consistently straight with equal board width, it just whines almost like a belt is slipping???  Any help from you veteran sawyers would be most appreciated.  Thanks again
Brucer
Welcome to the forum, John.
Does your LT28 have the power feed option? If it does, that could be the source of the whine.
Bruce    LT40HDG28 bandsaw
NPsawyer
It does have the power feed.  What could be going on with it to make it make a noise like that?   Thanks for your reply
NPsawyer
NPsawyer
Upload to YouTube and then post the link.
scleigh
NP, I saw with an LT28 also. When making a wide cut, especially in hardwood, I have to pay attention to the feed rate. I usually start the cut slowly and then increase the feed rate until the engine starts to strain.  At that point I have an idea of how fast I can make the rest of the cuts.
If you feed too fast, the drive belt will squeal , slip and even smoke. Also, you can cut faster than the blade can handle. I would recommend slowing the feed raste, since it cuts good with a new blade but begins to whine as the blade dulls.
NPsawyer
It seems like its worse the slower I go. Hopefully that video helps??
Sounds like a harmonic vibration to me. Hard to tell in 2 seconds.
Chuck White
Welcome to the Forestry Forum, NPsawyer (John).
Crossroads
Do you have lube going on your blade? I was cutting maple a few weeks ago and was being lazy about filling my water jug. My saw was making a howling sound, but as soon as I filled my jug and added water to the cut, all funny sounds went away.
ladylake
  Could be the blade pushing back against the guide roller flanges, I run my guide flange 1/4" behind the blade with real good blade life, too close will break blades fast.  Steve
Rougespear
I also get a similar sound under heavy load... haven't yet figured the cause.
Custom built Cook's-style hydraulic bandmill.
flyboy16101
Welcome to the Forum NPSawyer,
Mine dose the same thing I always assumed that it was normal and came with a heavy load/ going to fast. Never gave much thought to it.
Wood-mizer Lt35, International 504 w/ loader, Hough HA Payloader, Stihl Ms290, Ms660, LogRite Cant Hook
NPsawyer
Thanks for all the responses. I can't imagine this is normal, but maybe I'm just being paranoid. I just dont want to do any damage to the mill
Ga Mtn Man
Take a close (not too close) look at the blade guides when it's making the noise and see if the blade is running against the flange.
drobertson
If that feed rate is pressing the rollers then something bad is wrong. It had that as Jeff said a harmonic sound, bearings somewhere, the strange thing is others have the same or similar sounds.
ladylake
  Take a magic marker and paint the guide wheel flange, I'll bet the  magic marker is gone off the flange soon as the blade is dull a little or pushing hard in wide cuts.  I think if the guide wheel is not very parallel with the blade they will make more noise when the blade hits the flange.  According to WM the exit side of the flange should hit the blade slightly before the entry side which will pull the blade up to the guide rather than push it down when it hits, makes sense so I try and adjust mine like that.  These higher HP mills running less hook blades are going to push the blade back a lot more than a 16hp mill running a 10° hook which might not push back at all until the blade is dull.    Steve
MartyParsons
Hello,
Blade hitting the flange of the roller. When you hear the noise slow the feed rate down and see if it stops. You can add a little more lube to the blade and see if this helps. You may also want to change the blade hook angle to a 9 or 7 Turbo.
Hope this helps.
Marty
NPsawyer
Thanks again for the responses.  1). If this is a harmonic sound i.e. Bearing wouldnt it make the noise all the time
2) if the blade is contacting the guide flange is that something to b concerned about, should I adjust the blade out on the wheels so it's further away from guide rollers?
Not necessarily.  Your blade/blade guide should be adjusted to the distance shown in your sawmill manual.
pineywoods
I get the same sound on my lt40 when I saw large dry oak with a dull 10 degree blade. The teeth are scraping the wood rather than cutting...It's worse on a blade that has been sharpened and then set rather than set before sharpening. The raker teeth will be a bit higher. Set, then sharpen so all the teeth are the same height...
NPsawyer
I will check the guide rollers the next day I can saw, thanks guys. @pineywoods: I don't have the equipment to sharpen/set my blades currently. These are all new blades from WM and I'll be sending them back for resaw. On a similar but separate note; for this mill with the 19 hp engine cutting mostly oak, at least for the foreseeable future, would a 9 or 10 degree blade be better for this application.
Also:
Quote from: MartyParsons on October 30, 2016, 04:39:58 PM
Hello,
Hope this helps.
Marty
Marty the noise is significantly worse when I slow the mill down.
