shaper heads for table saw
Started by shelbycharger400, July 22, 2011, 06:54:30 PM
shelbycharger400
redbeard
Nice I like it. I have a similar cove cutter from a crown molding kit and it works like a champ. You will need 3hp or better probably for those heads. They are quiet and smooth.
jimparamedic
Yes take lite passes a power feed helps, But if you ever seen a saw blade kick multiple it 100 x. Like all power tools safty first fingers and eyes don't grow back.
shelbycharger400
that kinda puts into perspective what i was thinking.  i know that i would use a spring loaded idler for a double fence
jimparamedic
They do work good. Just becareful !!
woodmills1
I used shaper heads on radial arm saws years ago
did I say kickback............ :P
shelbycharger400
woodmills1
park ranger
Sears use to sell one and I see them in garage sales once in a while.  The body is something like 3/4" and the cutters set in and are locked with an alan head screw.
They work just fine, just bring them up thru your wood tablesaw insert and run the wood like you are cutting with a blade.  They don't cut as smooth as a shaper.  I would check e-bay for craftsman moulder or something and I bet you'll find one.  Or just get a used shaper .  I got a Inca shaper for a big pile of cedar I cut.
caveman
The moulding head cutter that I have belonged to my grand daddy and was made by Craftsman.  It holds three blades and a large variety of profiles are available from Sears.  It worked well the few times that I used it.  A feather board would help keep the work held tight to the fence.
Caveman
millwright
I have had one of the craftsman units for many years and it works very well. You have to be carefull about kickbacks as the other guys said. I increased the HP from 1 to 2.5 and it made a big improvement in the feed rate.
PC-Urban-Sawyer
Corb http://corobcutters.com/ currently manufactures and sells cutter heads and blades for tablesaws.
