Too much
Started by Peter Drouin, April 26, 2019, 06:13:08 AM
Peter Drouin
One Canadian had a little trouble. I think the truck is overloaded, all hardwood.
A&P saw Mill LLC.
License NH softwood grader.
Ed_K
Good thing he had them chained >:( :( :o.
Ed K
Skeans1
Looks like a highway trailer with drop in stakes probably thin wall tubing you could pull in and out by hand.
Southside
Can't be over loaded, there is still air showing at the tops of the bolsters.  ;D
White Oak Meadows
newoodguy78
GRANITEstateMP
Peter,
That's not overloaded.  He has a lot of RH turns to make on the way home and he's been working on his "set-up" after watching Day's Of Thunder  ;D
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Frickman
I don't see any stakes on the rear tier of logs.
Bruno of NH
Quote from: Frickman on April 26, 2019, 03:05:59 PM
That's what I see too
The state police go hard on the Canadian truckers .
20 years ago a Canadian log trucks load broke loose and killed two troopers in Twin mountain area.
The logs crushed the crusier.
Peter Drouin
The stakes snapped off. the road the truck was on is one of the worse around.
A&P saw Mill LLC.
justincase
He's a good driver works hard to make a living. I've had him on my jobs and is great to deal with. Feel bad he has to deal with that. Glad the straps held
Belt and Braces...
If one lets you down, hopefully the other one holds up your pants (or  logs)
So that one rates as in "Incident", not an Accident.
The local cops would want to know who certified the stakes that broke off etc, but that's better than investigating a  fatal accident.
Bruno of NH
Peter Drouin
Was he on the road from Franklin up to your place ?
That road was a mess the day I stopped over to see you.
