Slabbing some knotty Red Oak
Started by Stagerig, March 11, 2013, 08:53:29 PM
Stagerig
I picked up this very interesting piece of red oak from a local tree service that saves "special" pieces for me.  My slabber will only accept up to 4ft. wide and it took about 2 hours to whittle it down so it would fit on the mill.  It took about 5 minutes a pass to slab it once I had it on the mill. Somebody is going to get some awfully nice tables once this stuff is dried in a year or two.
Peterson WPF with Slabber, Woodmizer LT40, Kioti 455 w/FEL, MasseyFerguson 1533 w/FEL, New Holland C185, Granberg MarkIII & MiniMill, Husqvarna 3120XP, 455, 385XP, Shindaiwa 575x2 & 757
Rob Bocik
POSTON WIDEHEAD
Now that BIG thang would make a nice hat rack.  :)
All I can say is that you are a very patient man  ;D.
isawlogs
 I would love to have a slabber, then I look at the weight of them slabs you guys are cutting and the envy all goes away... ;D
   Marcel
rambo
Knotty? I lost count after 12.  :D The things that people will buy that I make firewood out of.
Red Clay Hound
I thought I had milled some knotty logs.  I'm gonna have to redefine my notion of what constitutes "knotty"! :D
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
 ;D
All KNOTS and no log  :D.
You are a brave man!
js2743
looks like you found ET inside that thing.
Chuck White
That's quite a log you have there!   ;)
Should make some nice table-tops!
isawlogs
 The definition of log has been taken up a knotch, That must of been something to limb, sawing is taking it on another level, let alone drying it.
How thick are you cutting this to  ???
   Marcel
octam1
Nice!!! We slab them like that... we usually slab them 4" thick like that and weigh them down in the stack after stickering them really good to help them stay a little flat... we do them 4" thick so there is room to surface them after drying and them moving...
keep them flat and weigh em down, you will end up with some nice slabs after drying them for a while...
Charles.
KnottHead Custom Sawing & FabWorx
Ceres/Twain Harte CA.
WoodMizer LT40SHDG38 w/AS2 & Debarker
Lucas 8-20 Swinger w/60" Slabber & Planer
Solar/Dehumidifier Kiln in the worx
Stihl - 2x 026's, 044, 046, 2x 066, MS660, 2x 088 & 3x 075AV
mometal77
Too many Assholes... not enough bullets..."I might have become a millionaire, but I chose to become a tramp!
Stagerig
I have been cutting the slabs at around 3" thick.  We are coating both sides with beeswax end-sealer and then stacking them on top of each other with 1" stickers between.  We then let them air dry for a year or two. We have had great results with this method and made some mighty fine tables with just light planing.
Rob Bocik
We have gone to thicker 1.5" stickers. This has sped up drying a bit and taken care of the larger bug issues. I think the extra space helps keep the roaches and things out it also allows the lizards more spce to get in and eat them. This is FL after all it is a bit buggy in more ways than one.
