The diesel upgrade
Started by Kingcha, December 03, 2012, 10:49:45 AM
Ironwood
Cool little diesels.......I dont know, I suppose as stated it would depend upon the specific diesel they are using..... I have a TON of Yanmars here and they always fire right up and are REALLY dependable. I just borrowed a buddies homemade high performance log splitter with a little diesel, it is REALLY effiecent and doesnt give off really any offfending fumes. We had some temps in the mid 20's and she fired right up. His was a "Perkins", not sure if it is grey market of not, but neat little unit and used hardly any fuel. I think one thing to consider is the lack of complex ignition systems on diesel engine and the BIGGIE, many small engines are suffering from Ethynol issues, I know current production gasser power units may have solved that, BUT what will they add/subtract next? Diesel is pretty straight forward, some additives if necessary. But no show stoppers like Ethynol . That would be the REAL decision maker for me......AND the fuel will keep REALLY long periods of time verses just a month (max recommended for gas as Ethy attracts moisture)
Ironwood
I had the 15 HP kohler gas engine on my first LT15, and on the one I have now, it has the 25 HP kohler gas engine.  The 15 HP did just fine, and the 25 HP does very fine.
MotorSeven
I'm glad you asked this question as I have been pondering the up-grade on a LT35.
Having a 300 gallon diesel tank(and a farm tax number) on the place makes me lean towards it. But the $2200 price difference makes me hesitate.
Dgdrls brings up a good point. I wonder if WM has the torque curve charts to compare the engines? I assume WM knows what they are doing when it comes to power plants, but seeing stats might be more convincing.
WoodMizer LT15 27' bed
