Author Topic: 100 ft dead pine  (Read 1989 times)
Offline slider
  • sawyer,trucker,tree service
100 ft dead pine
« on: April 14, 2021, 02:52:36 PM »
I am in my 11th year doing tree service work . we have many dead trees to deal with but today one taught me something .
I went up 70 ft and put a rope in it then i dropped down 20 ft and did an over and under cut with a wide hinge because the tree was so far gone. when we started pulling with the skid steer .the rope was not tight when it started to fall. i had 30 ft of big stem over me with not much holding it.
My bucket will go up to 75 ft but what is 5 more ft when you still have 25 above you.
i should have had the service to the house dropped and just dropped it in the yard.
11 years yes ,still learning,hell yes. glad to still be here .
al glenn
Offline barbender
Re: 100 ft dead pine
« Reply #1 on: April 14, 2021, 04:27:13 PM »
I think in tree work or anything else that is inherently dangerous, the day you think you've got it pretty well figured is when you're going to get killed. I'm glad you're still learning, Slider!
Offline slider
« Reply #2 on: April 14, 2021, 06:35:06 PM »
bare bender i  am.thanks.
al glenn
Offline GullyBog
  • It's not business, It's personal
« Reply #3 on: April 18, 2021, 06:37:21 AM »
Removing dead trees from urban areas is important work.  Thanks for what you do.
There might be a little dust on the butt log, but don't let if fool ya bout what's inside
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #4 on: May 02, 2021, 01:16:42 PM »
Al, I'm glad you are still with us and you avoided a potential disaster.  Those of you removing yard trees earn your money.
What's uglier than MagicMan's feet?
I should have posted, back in September, in "I did something dumb today" when I was pushing over a dead pine with a tractor and had a mishap. I did not post due to embarrassment but it may serve to help someone else avoid ruining their modeling career or worse.  There was a relatively small, 50' pine that was dead.  I used the tractor fork rack up high on the trunk to gently push it.  After it had a good amount of lean and the root ball was beginning to come out of the sand, I backed up the tractor and put the end of the fork on the trunk in order to get a little further away.  All was going superbly until the top, while falling through the top of a neighboring pine's limbs broke out and was hurled back at me.  It broke my nose and I got a hook shaped scar, but I considered myself fortunate.  The kicker is that there was an audience.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: May 02, 2021, 07:46:53 PM »
I accept defeat with de feet.  You is ugly!!  :-X
Offline caveman
« Reply #6 on: May 02, 2021, 08:09:55 PM »
Thank you sir, I take that as a compliment.
Caveman
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: May 02, 2021, 08:43:28 PM »
As it was intended.  8)
Offline slider
« Reply #8 on: May 03, 2021, 03:16:51 PM »
Dang Caveman that hurts just to look at it. Glad it was not any worse. I do many dead trees but i don't like nor trust them.
We did one last year near a power line that i could not piece down . I always cut 2 escape routs at the base so i don't get tangled up if i have to move in a hurry. We put a rope in it at 60 ft . I put a notch in it at the base and started my back cut when David started pulling. It broke 20 ft above me and 40 ft of top came down . Taking the time to clean out 2 ways to leave if things go wrong saved me that day. I just turned 71 but i can move when i have to.
al glenn
Offline caveman
« Reply #9 on: May 03, 2021, 03:47:45 PM »
I look at your age when I see your posts and I cannot believe you are 71.  You must have taken good care of yourself or Vic takes good care of you.  Standing dead trees can be ....(dangerous, profitable, eventful, non-eventful, a good place to raise woodpeckers, etc.).
That was the second time I got my nose broken.  It hurt both times and it keeps getting bigger.
Caveman
Offline Andries
  • Making buildings out of big curvy logs
« Reply #10 on: May 03, 2021, 04:53:35 PM »
Slider, I noticed what you did with your words there. Might @barbender  be the name of an exotic dancer?
 Sly dog!
Glad to see your post and to hear about your adventures as a climbing arborist. Keep on dodging those widow makers!
Caveman, DANG, that appears to be both lucky and Dang painful. But hey, it looks like your career as a stunt double for George Cooney is still safe.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline barbender
« Reply #11 on: May 04, 2021, 11:55:56 AM »
😂😂 No exotic dancing here, usually people's auto correct turns my user name into "bartender"- "bare bender" was definitely a new one!😂
Offline slider
« Reply #12 on: May 04, 2021, 04:05:08 PM »
sorry Barbender my mistake .
al glenn
Offline slider
« Reply #13 on: May 04, 2021, 04:07:29 PM »
al glenn
Offline customsawyer
    • The Custom Sawyer
« Reply #14 on: May 04, 2021, 07:42:18 PM »
Dang Slider and Caveman. I thought I was the only one that does stupid stuff. Making me feel better every day.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline barbender
« Reply #15 on: May 04, 2021, 08:03:33 PM »
No apology needed!😊
Offline caveman
« Reply #16 on: May 04, 2021, 10:29:13 PM »
Hang around me and I can help you boost your self esteem.  To quote my Daddy.  "It seemed like a good idea at the time".
Offline Clark
« Reply #17 on: June 23, 2021, 07:41:45 AM »
I thought that auto-correct was hilarious. Instead of “Senior member X2” I think barbender deserves a title there. Between manning the wet bar and the metal bar he could have his own one-man operation in the seedy part of town...but “dancer” would still be a good title!
Clark
SAF Certified Forester
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #18 on: June 23, 2021, 08:51:49 AM »
Remember it is only dumb stuff after the fact. It made perfect sense while we are doing it!
Offline Tacotodd
  • To learn and help
« Reply #19 on: June 24, 2021, 02:57:47 PM »
“It seemed like a good thing at the time”   ::)
Trying harder everyday.
Using dead standing hemlock, red pine and white pine & best transport in forest
Started by LoggingOn on Ask The Forester
Last post July 28, 2011, 03:19:12 PM
by LoggingOn
What do you do with a dead Pine?
Started by SawBilly on Sawmills and Milling
Last post September 06, 2002, 11:02:18 PM
by sawmill_john
Dead stacked pine
Started by woodman58 on Drying and Processing
Last post December 03, 2016, 02:22:38 PM
by GeneWengert-WoodDoc
Standing dead pine
Started by brooksmill on Sawmills and Milling
Last post April 07, 2007, 08:09:51 AM
by Minnesota_boy
