maple in kiln
Started by xlogger, November 21, 2019, 06:09:39 PM
xlogger
Monday I put a load of maple slabs in my kiln, they where around 20-21%. I got maybe only 2 gallons of water in the bucket the first two days. Today it's real slow drip, I open the door and it fog my glasses right away. I open the screen to look at coils and very little water on it. Check mc got around 20%. I would think it should be a good drip with that. I try calling Stan but he must be out of the office today. dp 120 wb 75.
You think it might need charging, low on fluid?
YellowHammer
Do you know what the actual wetbulb temp was?  What was the moisture loss in the wood?
The compressor has a low pressure shut off that will turn it off if th Freon gets too low.  However, you may have a low charge.
If your system is working properly you should be able to reach in past the filter and feel the evaporator coils, they should be cool but not freezing.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
K-Guy
Hi Ricky
Sorry I was running around like a chicken with her head cut off yesterday. I'll call you in a bit.
Nyle Service Dept.
- D. Adams
Southside
 :o that has meaning around these parts!
White Oak Meadows
K-Guy
Quote from: Southside on November 22, 2019, 09:02:39 AMthat has meaning around these parts!
No chickens were harmed during my day. By the end of it I was to tired to chase them!! bat_smailey
I would of said something else if I had remembered your chicken fetish.  crow_smiley
Nyle Service Dept.
- D. Adams
Some things that you learn at The Project are better off left at The Project :D.
Southside
Folks names being one?   :D
White Oak Meadows
GeneWengert-WoodDoc
When a thick slab is at 20% MC, it will be drying slowly, especially when at 120 F.  How much wood do you have in the kiln?  Sometimes, even with low RH, air dried wood will go into the kiln and appear not to dry.  Actual, the surface is so dry, that humidity is a slow driving force.  You need heat to get the water moving.
What is the RH?  If it is too high, then the compressor is not removing moisture.  Are the coils cold?  If not, then what is making the compressor not work...automatic shutoff due to high temperature, low refrigeration fluid, compressor seals no longer working, etc.
If the temperature outside is 55 F, your glasses will be at that temperature, if the kiln has 120 F dry bulb and 80 F wet-bulb (low humidity), or any WB over 55 F, you will fog your glasses, even though the kiln is indeed  dry.  So, what is the RH?
If you have a pin moisture meter, take a thin piece of wood, maybe 1/8" thick and stick the pins into that.  Then put the meter with the wood on the pins into a closed plastic bag and  put it into the kiln.  This is to let it warm up without getting condensation.  Then in an hour, take it out of the bag, wait another hour and then measure the MC of the thin piece, making temperature and species corrections.  That will be the EMC, which you convert to RH.
Quote from: Southside on November 23, 2019, 07:56:25 AM
OK Bob, you score a point on that one.
