I'm not extremely experience when it comes to cutting with a chainsaw. But I'm not new either. I've been using full skit chains for most of my life. However I have a new MS660 that is the biggest saw I've ever used. The 36" bar on it is the longest bar I've ever used as well.
I just can't seem to be able to get a plunge cut started. Even if I try to start it with the side of the bar & rotate in. The saw just kicks back to hard for me to keep it in the cut. Any suggestions other then eat my Wheaties?
Thanks to the Mod for fixing this for me.
Might have to change from a skip chain and keep the rakers a little higher. Steve
Sounds like the rakers might be a little low. The longer the bar the more leverage it has against you.
Two identical threads on the go here :D
What species of timber are you bore cutting and what position are you boring felling or bucking?
I was afraid that might be the answer. I did buy a chain with all the teeth just in case the full skip chain wasn't any good to rip with on that big of a bar. The full skip chain is brand new so I can't add any to the depth gauges. I didn't notice until I got home but this saw has a yellow bar & I've always bought green bars & used the yellow chains on them. Actually I know what the colors mean but is there really any difference in the bar itself?
Sorry
I just seen a double tap must have taken place. My phone browser doesn't work well with this site. I'll ask a Mod to merge them. The only tree I have tried a plunge cut on so far has been a oak. I tried several times & just couldn't get it started. Kickbacks with a chainsaw is about the closest thing I know to something that scares me so after about ten in a row I have up & didn't try any more. This saw was kicking so hard it was all I could do to hold it. I can good them in place & power on through until the saw will stay in the cut with my other saws. This saw has to much torque for me to do this tho.
Quote from: Kingmt on September 30, 2015, 09:04:36 AM
You'll never find a 36" green bar. But if you can find one of these green Oregon small radius bar noses you can bore cut effortlessly. Put it on any Oregon PowerMatch bar length of your choice
Still lots of new ones around if you search, their called Oregon Power Match Double Guard available in 3/8" and .325 .
(https://forestryforum.com/gallery/albums/userpics/21589/Picture_071-1.jpg)
Bore cutting with a full skip chain is only recommended for softwood not hard oak.
Start your cut at WOT always.
You have to kind of start your plunge using the bottom radii of the bar tip .
Be very careful because if catch the top of the bar it will come back on you .
BTW a plunge is not for a novice to be fooling with ,just sayin .
Someone suggested to me that when plunge cutting or boring and when the saw starts jumping around to rotate or twist the bar to get it to settle down. I was skeptical but it worked. Guys HolmenTree may do this without even thinking about it.
Quote from: HolmenTree on September 30, 2015, 09:19:38 AM
I find the double guards silly, and will never use them, but each to his own. A small tip on an otherwise wide bar isn't a combination that sits well with me.
Plunge cutting with 11t tips in 3/8" is just fine (full comp chain of course), but you do of course have to start the cut with the underside of the tip, and be prepared for some pushback when inside the wood.
You have to be awake when doing it, regardless of bar - and preferably sober. lol
A lot of knowledgable people have said that the 13t noses are the most effective for bore (plunge) cutting - but I haven't tried that.
Quote from: SawTroll on September 30, 2015, 10:42:55 PM
Nothing silly about them at all, When these noses were manufactured and sold there wasn't any internet sites or SawTroll. I think your thinking of today's laminated Double Guards for the weekend cutters.
Very smooth cutting bar and did I say "safe"......with that 9 T nose on a regular contour bar.
I wouldn't call kickback injuries in 6 logging camps going to zero silly when these bars were used.
We logged with these noses in pulp wood for decades starting back in the 1970s when they were the single contour banana nose and they proved their worth and reliability.
Now the Oregon laminated one piece Double Guard bars on the market today are what you call silly :D
I had some of the same problems when i first learned to bore cut, which hasn't been that long ago. I won't say my way is right, but it helped me while learning to bore cut. I get my left hand low on the handle, my right wrist and elbow locked and forming an L while my right elbow is against my right thigh, knees slightly bent. Start the cut with the bottom of the tip and slowly walk yourself to the right, while lightly pulling the saw to the left with your left hand. This is all done at wot. Hope this doesn't confuse you, but i'm not the best at explaining things. You already know the dangers of kickback, and if anyone reading this sees an error in my explanation please chime in, i'm not a good "explainer". I cut oak hardwood mostly with a 20" bar using oregon lpx, and a 28" bar with full skip for the bigger trees, and i bore cut most of the timber i fall. It's like anything else , the more you do it the easier it will be. Hang in there you will get the hang of it.
Great replies that are very informative. Altho now I have another question. What are you talking about when it comes to 13t, 11t, & 9t bars? Is that teeth on the roller? I thought I knew a little about cutting wood & saws until I tried to learn more. Now it seems like the more I learn the less I know.
PR
Your explanation works well for me, and would consider it just what I do. Rarely get any bounce back out of the initial start of the tip of the bar into a plunge cut.
WOT and sharp chain are important, IMO
Yeah the explanation was good & useful to me. I didn't explain this in the first post because that cut is over but part of my problem was the hight I was cutting. I was limbing a tree. The limb is about 14-16" & was slightly over my head. The reason I was trying the plunge cut was I didn't want to try & hold the saw up there with the chain pushing back at me to do a under cut then finish from the top. Instead I wanted to plunge & come down then move back to the top. Instead I cut the limb closer to the main trunk & let the whole thing crash to the ground. I figured that cutting such a heavy log under that much pressure that something really bad was going to happen half way through the cut. It ended up only splitting a little & really wasn't as bad as I thought it was going to be.
Kingmt, rule of thumb you should never have to cut above shoulder height for safety sakes.
But it sounds like you have some very nice oversized oak, something I never see up here.
Quote from: Kingmt on September 30, 2015, 11:25:32 PM
When you understand the designs of your hand tools it can make life wood cutting a lot easier.
SawTroll mentioned about a 13 tooth 3/8" sprocket nose bar. The only bar sold today in that large nose size is a 25" Stihl bar that appears to have a market for steady professional bore cutting applications in hardwood harvesting.
The last time Oregon made them was in the early 1980s, it was called the medium contour bar. The reason it's preferred for heavy bore cutting is it's larger sprocket and bearing geometry offers more durability in steady rigorous bore cutting.
A 11 tooth 3/8 sprocket nose bar is your standard yellow grade ES Stihl , PowerMatch Oregon bar or Carlton/Windsor Speed Tip bars.
A 9 tooth 3/8" is your green small radius bars mostly in laminated design, they offer excellent kickback reduction especially in bore cutting and limbing. Only drawback is durability with it's much smaller sprocket bearing design . But having said that the increased kickback energy and vibration of the larger noses can also cause their bearings to fail.
The 9 t noses burn out easier when a high h.p. powerhead turns the chain when the nose is pinched in a cut from my experience.
But if your only bore cutting a few trees and not for a living I strongly advise you to put a Oregon Double Guard nose on any Oregon PowerMatch bar .........from 16" to 42".
[/quote]
Holmen, I think you just answered a question I didn't know I had! When I bought the little MS170 I wondered why it had such a small nose bar on it. Thought it almost looked like a wood carving nose, it must have been for it's anti kickback properties. When I finished building a small 8x12 log shed, using the 170 to cut notches in the logs, the bar was worn out so replaced it with a 50 gauge bar with a wider nose. Like it much better!
Loren
Here's a pic from 1983 of me cutting with a prototype Oregon PowerMatch bar that I was field testing when logging. Wasn't told I couldn't play with it :D
The bar was later introduced in 1985. I also had a prototype radial port rim sprocket on my Jonsered 630 .
This bar's sprocket tip has the original banana nose style Guard Tip that was so successful in the pulp wood industry. This contour nose was never introduced in the PowerMatch bar as they added a double sided contour to make it reverse able when turning the bar.
Thus then called the Double Guard.
Our forestry company's policy was safety bar noses on all saws in the logging and mill divisions.
Kick back injuries were zero.
Stihl had a hard time with this as they didn't supply their pro saws with safety bar noses .
All Stihl saws on the jobsite had to be equipped with either Oregon Guard tip bars or Windsor Mini Pro bars.
(https://forestryforum.com/gallery/albums/userpics/21589/20151001_102219-1.jpg)
(https://forestryforum.com/gallery/albums/userpics/21589/20140326_150200.jpg)
(https://forestryforum.com/gallery/albums/userpics/21589/20140326_165144.jpg)
Quote from: Caloren on October 01, 2015, 11:43:15 AM
Loren
If I'm not mistaken those little MS170 bars are the smallest of "small bars". Probably 3/8 Picco with a tiny sprocket nose and a laminated design.
A totally disposable cheap bar. My HT 75 polesaw has one of them.
Quote from: HolmenTree on October 01, 2015, 12:11:41 PM
Loren
Now that I think about it those little MS170 bars are .043 gauge in mini Picco. Almost as light as they go except for the new Stihl 1/4" bars for the battery saws.
These pro grade 9 tooth safety tips I'm preaching about can take a .063 gauge chain.
I was going to bore a leaner the other day and with the old fat nose bar I was using I never did get it started or lost interest anyway. Really wasn't that big of a tree and I was going to have the whole side gnawed off.
QuoteI was going to bore a leaner the other day and with the old fat nose bar I was using
What is an "old fat nose bar" ? Just curious how it compares to those I use to bore, with no problem.
Older bars seemed to have a round radius as opposed to more or less elliptical on newer bars depending on the bar.
Everything I thought to try the bar just kicked out, but I am no faller by any stretch.
Quote from: HolmenTree on September 30, 2015, 11:07:16 PM
Not at all, I didn't even know those existed!
I see your point regarding pulpwood cutting though.
Zerojunk
I suspect it is technique then, as my bars are quite standard that I've used near forever...
Keep the chain speed up and good hold on the saw... and more practice.
The bar on my nearly new MS362 that I will flip over when switching to the alternate chain.
(https://forestryforum.com/gallery/albums/userpics/10180/Stihl362_bar.jpg)
I knew less about chains & bars then I do now when I bought my MS180 & the dealer put a .043 Picco on it. I hated that chain & bar but loved the saw. So I got a Pollen & modded it to work since I couldn't find anything else for it. A few weeks ago I decided it was time for a sprocket & I got to looking to see what bar could be put on it.
I found a Oregon that was .050" & love that bar on this saw. Of course I could have bought a Stihl .050" bar & chain for $70ish but this one was only $25 for both & it cuts better then the Stihl chains I have been using. I only run a 14" bar on that saw.
Quote from: beenthere on October 01, 2015, 06:17:20 PM
Zerojunk
That's my experience as well - no tip size really is a problem for bore/plunge cutting, when doing it properly. Always be prepared to contain push-back when the upper part of the tip is in contact with wood.
Zerojunk
That is a modern tapered elliptical nose. Some older bars, even Stihl bars, had a larger radius at the tip. They designed away from them because of kickback.
Sawtroll, I know a lot more about fixing saws than using them.
I've learned a lot on this thread. I love this place. It's almost like Holman tree knows what he talks about. ;D
I'm no feller but, have fell quite a few and, bore cut nearly every one of them due to running the shorter 18-24 inch bars on the saws I've owned. One thing is a constant. You have got to get the bore started with the underside of the bar tip. Once notched, I throttle up and start cutting near the backside with just the tip. At the same time, I start letting the tip cut back towards the notch. I'm really not cutting it as much as scoring and just allowing the saw to track the cut. When I get almost perpendicular to me, I push the saw forward to perpendicular and, plunge it in and work it to the backside of the notch. then I cut to the trigger with the top side of the bar. I switch sides and, start the cut with the underside of the tip an inch or two from the depth of the notch I want. As I let it start to cut and get sufficient distance to keep from cutting my hinge wood, I bring the saw perpendicular and plunge it. I work back to the notch to get it even and to the thickness I want it and, then bring it on around to establish the trigger. I pull it, then cut the trigger loose. It is slower than what pro's do on some trees but, it is fail safe and, has kept me alive so far.
This method depends on body position to the saw when starting and requires a bit of moving while cutting. But, like I said, while slower than the professionals, it is safe and has kept me alive. I'm no pro but, I like being alive. Give it a try. Just remember, the bottom side of the tip is where the bore starts. Once you get it established, it will go right on through as long as the cut isn't being done with the upside of the tip. God Bless
Show us a pic of the old fat nose bar you had trouble with on the leaner. Sounds interesting.. and I like to know more.
Speaking only for myself a plunge type cut is one I use very seldom .About the only time is on a heavy head leaner as a step to prevent a barber chair of which I had one and never care to have another . :o
Quote from: Al_Smith on October 01, 2015, 10:03:32 PM
I often use plunge cuts on leaners, just for that reason - even though birch isn't very likely to barberchair. It usually is too twisted and knotted to do so, but you never know....
The open face bore cut completely changed the way i cut timber. I know its not for everyone, or every tree or situation, but it works very good for most of the timber i cut. when i learned the technique, i figured i might use it on 10 percent of the trees i would fall, but after doing it awhile and getting more comfortable with it, i now bore cut probably 90 percent of the time.
Does this forum have a "like" button when ya like what someone says?
I think I am like many folks here when it comes to felling skills. I consider myself a competent amateur but no professional.
Lets' see.
Well, it is in the gallery somewhere. Old round nose Stihl 3/8 VS new Carlton 3/8 . I don't have a new Stihl 3/8 so may be apples and oranges. But, you will notice there is no taper at all, just a straight line to the nose.
(https://forestryforum.com/gallery/albums/userpics/34383/003.JPG)
Quote from: 49er on October 01, 2015, 10:46:16 PM
I haven't seen any such feature here....
Some times I have wanted it, but mostly I don't miss it.
As I recall, the "like" button has been discussed, and got a smiley_thumbsdown
Just use our words to say we like something as it is much more personal, seemed to be the jist of the members.
Quote from: beenthere on October 01, 2015, 08:59:23 PM
I posted the photo in case you missed it.
Quote from: ZeroJunk on October 02, 2015, 11:00:13 AM
Lets' see.
M
Yup that's a big old hard nose bar, equivalent to the 13 tooth sprocket nose 25" bar Stihl sells. Radius diameter is about 2 7/8".
The smaller one is a 11 tooth sprocket nose Oregon PowerMatch bar about 2 1/4" diameter.
I like the like button on other forums. If nothing else I can show I'm still reading my thread & appreciate the post when I don't have anything yet to add.
smiley_thumbsdown
Save it for facebook and the "like".
:D
...or if you "like", then use smiley_thumbsup
;D
Are there other forums ??
I don't use Facebook to know they even had a like button. I usually don't post again to keep people from looking again only to find there isn't any new information. I used to be quite active in the Android community & I'm still a Mod on androidarea51.com but as far as forestay forums I don't think there is. I've never been to another one anyways. So far I've gotten all the information I can process from this one. However I still have hobbies of farming, Android, & machining.
Quote from: beenthere on October 03, 2015, 02:28:32 PM
smiley_thumbsdown
:D
;D
It appears you were too subtle, bt. ;)
On the subject, Bore cutting , open face knotch ect.. ect...
I have always thought this guy does a good explanation and demonstration of safely felling a tree using some of the methods discussed in this thread.
If you haven't already watched this I hope you like it as much as I did.
https://www.youtube.com/watch?v=Teb2bQsqx44&feature=player_detailpage
That is the safest way I know of feeling a tree. God Bless
Quote from: WV Mountaineer on October 03, 2015, 11:31:11 PM
Great video but he needs a sharp chain ,that chain is making dust not chips 8) 8)
So, what I do, take it with a grain of salt, and bear in mind I cut softwood. But someone taught me a trick as I was learning. You roll the saw in as stated before, then when I get in a little, if I feel like she's gonna kick, I twist the bar slightly and pull up a little on the rear of the saw. This creates a pocket in the cut that is very hard to kick out of. I can bore skip very easy this way.
That's a good thing to keep in mind. Thanks for sharing. I try to stay away from bore cutting unless its a tree I worry about splitting like if its a hard learner or some species I just bore cute automagically like hickory but I rarely bore cut softwood unless I wanna play around a little just how I like to do it to each his own!
Quote from: Spartan on October 04, 2015, 07:57:06 PM
Yep, it works. This is what I said in post 10.
Sorry, didn't catch that
Quote from: Spartan on October 04, 2015, 11:12:37 PM
No problem. This technique does work well. I don't know if many people do it. I get a lot of blank stares when is describe it but I am use to that.
does it throw off lining up your cuts?
Quote from: 4x4American on October 05, 2015, 06:52:39 PM
No, not noticeably.
Tried another tree that was easier to hold the saw right & it was a easy task. I guess it was just the awkward position & a powerful saw talking a big bite.
Quote from: 346xp on October 04, 2015, 05:43:25 AM
There isn't a thing wrong with that chain. When you cut with the grain putting your top cut in an open face notch, it throws fine dust like that. You'll notice when he is cutting the tree perpendicular, it is throwing nice chips. It is just the difference with the cut in reference to the grain run. Not a dull chain. God Bless
