gearmatic 9 skidder winch need help
Started by jocco, November 19, 2011, 09:25:41 AM
jocco
Do any of you have a manual for these and also any one have parts?
You may check out but you will never leave
madmari
I have one for a model 19. Is yours a 9?
I know why dogs stick thier head out the car window.
jocco
Yes #9 there is differences in the 19 and 119
John Woodworth
The mdl. 8 and 9 are the same, 19 diffrent, do you have a problem? if just looking for a manual try: garrettskiders@hotmail.com. if you have a problem I can help, have 30+ yrs. Gearmatic expierance.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
jocco
John i need to put a couple bands in it and fix the clutch cylinder. Local dealer has parts. I have worked on gearmatic but no exspert.
mr T
 Hi Jocco  You can download manual from paccar  http://www.paccarwinch.com/pdf/j-152c.pdf  Good luck i gave up on mine and bought a Wallenstein I have 2 8a winchs torn down now
