Lasershark, switch to the 7/39T silver tip and you will be even happier.
Quote from: Stephen1 on October 19, 2021, 10:19:42 PMLasershark, switch to the 7/39T silver tip and you will be even happier. Is that the case even though I really only cut Douglas fir and cedar? Not too many hardwoods in my area... unless you count alder, which is a pretty pliant hardwood.
I think it would, my 40 hp Lombardini pulls them with plenty of power to spare. I really don't notice much of a difference in power between 1.25 and 1.5" bands, probably if you only had 20 hp you would.
Do Y'all think my 35hp Yanmar diesel would have enough grunt to run the 1.5" .045 Silver Tipped Turbo 7s? I like what I am hearing here about them. hugs, Brandi
Quote from: Stephen1 on October 19, 2021, 10:19:42 PMLasershark, switch to the 7/39T silver tip and you will be even happier. Is the tooth spacing 1"? I'm ordering the equipment needed to sharpen those blades and the manufacturer needs to know.
Started by MbfVA on Sawmills and Milling
Started by weimedog on The Outdoor Board
Started by POSTON WIDEHEAD on FOOD! FOOD! FOOD!
Started by Piston on General Woodworking
