Author Topic: New Moultrie Feeder  (Read 471 times)
Offline TroyC
New Moultrie Feeder
« on: May 02, 2022, 06:51:41 PM »
Just received my order of a Moultrie Unlimited feeder, the one with the electric shocker for the varmits. The squirrels are terrible on my older feeder so I'm gonna try to shock them away.
Anybody here use this feeder? The reviews I read are not super encouraging but the squirrels are relentless. Haven't seen raccoons or possums bothering, just the squirrels. I have the older feeder set up now with a real time video monitor so I can watch it from anywhere. I really enjoy watching the deer, they are getting ready to drop fawns now.
The squirrels climb the legs and sit on the feeder motor, spinning the plate and chewing on the plastic. I think I'll try the PVC pipe on the feeder legs, have read that helps. Just wondering if anyone here has has good/bad luck with this zapper model.
Offline thecfarm
Re: New Moultrie Feeder
« Reply #1 on: May 03, 2022, 05:42:04 AM »
This might work for you. Or slow them down some. Might be too big, but may give you an idea.
something to put around the legs
I have one around the pole on my bird feeder.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: May 03, 2022, 09:03:20 AM »
   I have not used the shocker on mine. I buy the ones I attach to the bottom of a plastic barrel. These have a mount I leave on the barrel and remove the feeder at the end of the year I remove the feeder motor unit and leave the barrel and mount till next year.
   I hang mine on a cable between 2 trees about 20-25 above ground and run a winch cable to through a pulley on the cable to lift the heavy filled feeder. I hook the winch to a handy nearby tree and crank the feeder up and down as needed.
   I had trouble with squirrels and coons chewing through the plastic on the top of the barrel. Once I greased it good with WD40 and watched a big fox squirrel jump on and fall off the next day but now I get a piece of thin aluminum flashing about 14" X 14" and cut a hole in the middle and run the rope through it and to the barrel and that seems to be working to keep them off.
Offline TroyC
« Reply #3 on: May 04, 2022, 08:21:45 AM »
Just a heads up- went to get a 6v battery for the feeder yesterday. I live in central Florida, shouldn't be a problem, right? You know, just those plain little rechargeable 6 v batteries.
Two Walmarts, nope, don't carry them anymore. Special order. Lowe's, nope, special order, takes a week. Home Depot, yep, got them! Only 24.00 each. What? They usually run 10.00.
OK, enough wasting gas. Push Amazon button and 2 or 19.98.
Just thought I'd let you know before hunting season. Get 'em while you can!
Offline Ron Scott
« Reply #4 on: May 04, 2022, 06:36:54 PM »
A friend of mine had a shocker on his feeder to jolt the squirrels. He said that they started liking the jolt and it attracted them more. He said that it was funny watching the hair go up on their back; but he had to resort to shooting them off the feeder with a 22 Cal bullet or high-powered pellet gun. :D
~Ron
Offline TroyC
« Reply #5 on: May 04, 2022, 06:53:04 PM »
Yeah, did that also but I'm not there all the time. Gave me a reason to put a new scope on the old .22 and sight it in at 80 yards. I have a real time live camera on the feeder so I am looking forward to watching the squirrels reaction to the zapper. Deer are ready to drop fawns now and it is a treat to watch them play and grow.
first power feeder
Started by hackberry jake on General Woodworking
Last post July 21, 2014, 10:35:12 PM
by tule peak timber
Power feeder
Started by pasbuild on General Board
Last post December 02, 2004, 09:40:36 PM
by pasbuild
Franken-feeder
Started by DMcCoy on General Woodworking
Last post December 28, 2018, 02:29:08 PM
by alan gage
Log Deer Feeder
Started by POSTON WIDEHEAD on General Woodworking
Last post October 06, 2014, 08:19:18 AM
by 21incher
