backhoe from scratch and scrap
Started by grouch, June 06, 2017, 09:06:12 AM
Crusarius
I have a jeep Comanche like that. good new is the jeep will rot away to nothing before my heirs will get stuck with it.
grouch
Boom and dipper pins.
I didn't like the mess I was making with MIG, so I went back to 6011.
Boom pinned to the base, finally.
Note the weld stringer on the dipper bracket. Normally that would mean, "tear here". Here, it was an attempt to pull that bracket back into alignment.
Didn't work; notice the sliver of daylight in the upper right.
Time for the weedburner. Note the pin is already in place. It was close enough to drive in and the heating is to relax some of the strain so it is possible to get the pin back out.
This is not quick.
Hot enough for bacon; not hot enough for biscuits.
It doesn't have to reach forging temperature but it does have to get hot enough to move and accommodate that pin.
That looks about right. Let it slowly cool with the pin in place.
Find something to do that interests you.
Ljohnsaw
So I was searching for something and it popped me into the middle of this older thread.  So I read to the end then started at the beginning to see what the finished tractor looked like and then continued back to the middle. ::) :D What a great read!
So, how's it holding up and performing for you?  I did notice that you put the loader cylinders on "upside down" compared to most I've seen. Any particular reason for that?  It just makes for a lot of hoses that must travel a bit.
John Sawicky
grouch dropped off in October, 2017 and I was unsuccessful contacting him. ??
