Making an Ambrosia Beetle Riddled Spalted Pecan Coffee Table
Started by WDH, April 14, 2015, 09:10:17 PM
I am making a 36" x 36" x 22" high coffee table out of 5/4 pecan that has a lot of character to say the least.  The basic design is by the customer.  The legs are 2" square pecan.  Each leg has two mortises for the aprons and a dado groove for a shelf.  The legs have inside tapers below the shelf.
I chamfered the edges of the boards on the top to create a planked look.
The shelf is a little funky too.  All the black is from a fungus associated with the ambrosia beetle holes.  Nobody can do rustic like Mother Nature.
On the aprons, I put on a bead to create a shadow line.  I pegged the tenons with a 3/8" diameter, 2" long walnut peg.  This thing is never coming apart.
Here is the table dry-fitted together.  Not sure how the customer will want it finished.
Just a simple project.  I continue to be inspired by Tule Peak Timber.
Glenn1
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Andy White
Danny,
A really fine looking project you have created there! Is the planks for the top and shelf edge glued, or biscuited  or dowelled? The beading on the aprons is a good look . You sure make that  smiley_devil smiley_devil smiley_devil [Pecan] look great.      Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
POSTON WIDEHEAD
I actually love Pecan lumber riddled with beetle holes contrasting with the redish heartwood.  Customers went crazy over it, and I had no trouble selling items built with it.
Andy,
Edge glued with biscuits.
MM,
I have some pecan logs that I am covering with planer shavings.  The shavings will get wet, and hopefully, in the heat of the summer, the logs will cook.  Also hopefully, the ambrosia beetles will go to town too, and have a party.  The wood for the table resulted when I left some pecan logs stacked off the ground, and sorta forgot them for a year.  When I sawed them, this lumber is what I got.
Serendipity.
Great looking table... anxious to see it with a finish..  (and finished too  ;D )
customsawyer
www.thecustomsawyer.com
Nice table. I like the way the aprons are joined to the corners.  ;D Never have to worry about the shelf neither, I have made a couple items with that type of shelf, plus I groove another at a 90 and fit side pieces edge glued, you'd have to bust the legs off the thing to get that shelf out. ;D
Peter Drouin
Nice, The work of a fine woodworker. Good job,  8) 8) 8)
tule peak timber
ely
that is a great looking table, I wish I was set up and had the smarts to do those joints. :P
LeeB
Is it glued up already? I'm a little concerned about the shelf. If it expands much it may break the legs, unless I'm seeing things wrong. Sure is pretty though. I have a whole bunch of pecan like that, if the PPB's haven't eaten it yet.
samandothers
WOW  really pretty.  I look forward to seeing the finish if you apply versus customer.  I am surprised by the size of the black from the Ambrosia.  I am not familar with Ambrosia riddled Pecan some that may be very common.
The streaks get long in maple I know. Sometimes you really have to look to find the pin hole.  :D
Lee,
I have used this shelf design many times.  There is enough give in the legs to accommodate seasonal movement.
POSTON WIDEHEAD
Quote from: WDH on April 15, 2015, 08:11:01 PM
Lee,
What about state line movement? If it fits (in my truck), it ships,  :)
You stay away from here.  I will have Julio watching for you.
I've never had any trouble with that type of attachment either.  :)
gfadvm
A beautiful table with some real character. Looks like that pecan dried flat. Was this a standing dead tree when cut? My standing dead pecan and hickory have behaved better than green when being air dried.
Forgot to add that I love the joinery on this table!
hackberry jake
It's going to come alive once the finish gets applied. Sure looks like a rock solid table. How did you do the tennons and mortises?
Andy,
The tree was cut down green in March and left exposed to the elements, stacked off the ground for a year, then sawn.  I had other logs to saw, plus, the grade on these logs was not great, and I was dreading sawing them.  It was a nice surprise when I opened them up.
Jake,
I have a mortising attachment that fits on the drill press.  Like the one in the video.  It uses a square chisel with a drill bit inside it.
https://www.youtube.com/watch?v=hxyWfze3qzQ
The tenons were cut on the table saw using a tenoning jig exactly like this one.
http://www.wwgoa.com/tenoning-jig-how-to/
lowpolyjoe
woodweasel
dablack
Pecan is always a beautiful wood but what you have done with it, really takes this piece over the top.  Beautiful table for sure.
Building my own house in East TX
5quarter
   Great table! I've got some knarly hickory slabs that are similarly "rustic". Makes me want to go dig them out.  ;)
   As a sidebar, a clever way to attach lower shelves to legs that was used for many years involved and eye bolt and screw. the eye bolt was threaded into the leg and the screw passed through the eyebolt into the bottom of the shelf. not only was it simple and solid, but it allowed for some shrinkage without distorting the legs.
Blue Harbor Refinishing
gfadvm
Thanks for the reply. I'm always looking for a way to get these woods to "behave better" when drying.
ron barnes
Beautiful table with excellent woodworking.  Thanks for posting.
Jemclimber
Very nice and thanks for showing. The pins are a nice touch.
lt15
Lud
mesquite buckeye
I thought you didn't like pecan. say_what
;D
Pretty cool, by the way. :)
It is the  smiley_devil.  Some things in life are beautiful, but they come with a kick.
POSTON WIDEHEAD
Quote from: WDH on April 19, 2015, 08:07:00 AM
Good 1.  :D :D :D
Mooseherder
I don't know how I missed this project up until today.  Nice table WDH. :)
POSTON WIDEHEAD
Quote from: Mooseherder on April 19, 2015, 11:05:29 AM
Moose, you need to get busy and build something. Your tables are pretty nice to.  :)
Mooseherder
yukon cornelius
I missed this project also. that is beautiful! I have never tried anything like that maybe in the future I will
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Lawg Dawg
yes sir that is pretty nice!  I like the wood floor in the shop also!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
YellowHammer
That's a sweet table, I bet it's got a little heft to it also. ;D
Problem with building it out of pecan, is the customers will start buying more and more of them, and then, before you know it, you'll have to mill more pecan!   smiley_devil
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
mesquite buckeye
Sounds like chiltepines... ;D ;D ;D
The WoodYard
Maybe there is a market for ambosia beetles. I'll take a few. Your shop is too clean! I'm embarassed..
Rick,
Check out this thread.  I am trying to make some more ambrosia beetle riddled, spalted, pecan.  Next time you come down, maybe some will be ready to see.
https://forestryforum.com/board/index.php/topic,84241.msg1287209.html#msg1287209
The customer really liked the finished coffee table.  Here is the original in the customer's living room with the varnish applied for reference.
The reason that I am posting this is because the customer wanted a matching sofa table made from the same wood, and I had just enough to make the sofa table.  The top is nicely spalted, and there are the characteristic black ambrosia beetle holes that you see in pecan.  Made in the same style, but rectangular, not square.  19" wide, 24.5" long, and 24" high.
PC-Urban-Sawyer
ron barnes
mesquite buckeye
Left Coast Chris
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Carson-saws
Let the Forest be salvation long before it needs to be
drobertson
bkaimwood
bk
Ron Scott
~Ron
Den Socling
Isn't it strange that stuff that would have been unacceptable a few years ago is now considered pretty?
Depends on the local market. Anything with bug holes or stain would be tough sell in these parts.  ;)
Rustic is in style now.  I sell an amazing amount of wood for farm tables.
Darrel
1992 LT40HD
Okrafarmer
Very nice, Danny!
Almost thou persuadest me to be a wood-worker!
Now as far as culturing ambrosia beetles go, great going for you if you like to do it with devilish wood, but my ornery old self would envision culturing it in maple or other woods more easily milled and worked!
;D  :D  ;)
Now selling Logrite tools!
Pecan  smiley_devil
Sold this pecan yesterday to a custom furniture maker for a table top.  A full 2" thick planed and the wider boards are 17" wide.  It was a  smiley_devil to handle off the mill and a  smiley_devil to plane by myself, but I managed to get it done without getting crippled.
I'd be making the recipient tug and push on them planks for a while. :D
POSTON WIDEHEAD
Carson-saws
