someone had a bad day.
Started by BargeMonkey, September 09, 2015, 07:50:02 AM
BargeMonkey
 My wife saw this on FB last night, on the same hill I came down the other night when I dragged that hydro ax home. It's a long 2-3 mile hill, don't want to start down in too high of a gear like this guy probably did. Don't know who's skidder it was but mustn't have been good.
mesquite buckeye
sawguy21
At least all he had to do was change his shorts, it could have been a lot worse.
starmac
Looks to be a highway truck, probably was a highway driver.
The driver has a tad more experience now though. lol
Glad no one was hurt.
CCC4
I can't figure out what happened there...did he jack knife while in reverse??
NH-Murph
Well, I can think of worse things to have on the trailer when one goes off the road.  At least you have a skidder there to pull yourself out!
sawguy21
Quote from: CCC4 on September 09, 2015, 02:36:48 PM
I would suggest too much speed and dropped the trailer off the edge.
Quote from: sawguy21 on September 09, 2015, 11:10:19 AM
Yeah, everything is still shiny side up   :D
dustyhat
Change his shorts , heck i would still be wiping ;D
Gearbox
If the frame isn't bent it will be when they get done with the wreckers .
Gearbox
BargeMonkey
 Real long hill with a gradual left turn at the bottom then a stop sign and 4 lanes of traffic. He knew he wasn't stopping and dumped it on the grass at the bottom of the hill. Could have been worse.  :D
wfcjr
Quote from: BargeMonkey on September 10, 2015, 08:58:23 AM
Sounds like he used  judgement to end a bad situation....
The laws of physics are very stubborn.... momentum = mass x velocity
Always amazing where weight is your friend in moving dirt, moving logs & stability at low speeds.
But crank the speed up a bit and weight, or more appropriately, mass gets a mind of its own.
