stihl 200t leaking gas under carb
Started by mailman, March 11, 2017, 07:07:26 PM
mailman
 I just picked up a used stihl ms200t. It sprays gas from under the carb at full throttle but runs fine. It doesn't seam to leak at all other than full throttle. I haven't tore into it yet. What should I be looking for most likely?
joe_indi
It could be something as simple as a fuel hose leak or a loose pump side screw.
Check both possibilities
Joe
