Beginner Sawyer With Questions???
Started by JWright, July 02, 2012, 11:10:02 PM
drobertson
there was a reply as to the negative results in adding water to steel in cutting operation, just have to say how do you think most of the machining gets done in all the machine shops?  The only issue with water as a coolant is when the cutter is extremely hot or, running carbide and using intermitant coolant, which shocks the cutter.
Soap water works best with most pump systems, diesel with gravity drip systems,  winter weather you need washer fluid with pumps and keep using the diesel with a drip system,  just my opinion.. David
Greg Brown
Quote from: Sixacresand on July 04, 2012, 10:49:28 PM
My dad's remedy for every thing was terpentine or chewing tobacco, depending what ailed you.
Ain't nothing better for a wasp sting than putting chewing tobacco on it.
Norwood MX34 Pro,  Massey- Ferguson 175
woodmills1
I use 50/50 bar oil and diesel from a cheap spay bottle(too hard to find good metal repair shop spay cans any more)
will never go back to water that can freeze
bandmiller2
Has anyone here tried water soluable oil,common in the metal working industry,it has anti rust additives.The old time water pump lube you added to the cooling system,that turned it milky,is simular. Frank C.
