Why so many 8 wheelers
Started by Firewoodjoe, August 27, 2022, 08:20:54 AM
Firewoodjoe
I've been looking for a bigger forwarder. Deere offers 6 and 8 wheel and yet 90% are 8 wheel. Why? I want a 6 wheeler. 6 cylinder.
Firewoodjoe
And why do the Deere's have rust/burnt paint on the side of the hood? Preheater is all I can think.
chevytaHOE5674
Because 8 wheelers float better allowing guys to carry wood over worse ground without as much rutting. Putting tracks all the way around an 8 wheeler it'll go places loaded you could never dream of taking a 6 wheeler. Theres also more tire on the ground for stability.
When we used to cut USFS ground we would be hauling wood out while the 4 and 6 wheeler guys would be shut down from the forester.
No idea on the JD machines. Haven't really seen too many UP close around here.
barbender
What Chevy said. Flotation and traction. I know very little about Deere machines other than they're green and the cab spins on some of them😊
Firewoodjoe
8 wheelers have no traction. I watched one all winter and what a joke. They require tracks. Even now in hills they need them. Pushing a truck loaded and they are spinning all over like on ice.
barbender
Running one and watching one are two different things😁 I have skidded hills with no iron, that I wasn't even sure if I was in Minnesota anymore. Absolutely once the snow and ice is present you need tracks and chains, but I can't see where a 6 wheel would've done better in that regard. If the woods are wet or icy you are screwing around if you don't have tracks and chains on, imo.
 Once I had to push a dead loaded truck, uphill with the brakes set because the air leaked off with the 8 wheel BuffaloKing. Put half a load of wood on the machine and away it went. If you're trying to push or pull stuff with a forwarder without any weight in the bunks, you're more than likely making a fool out of yourself.
chevytaHOE5674
We were on a job with a guy his 6 wheeler with tracks and chains sank to the belly pan. I took our 8 wheeler with one set of tracks and chains and drove to him, unloaded him onto myself, pulled him out, and then proceeded to skid 10 acres of wood across where he got stuck...
barbender
Chevy, even though I'm with you on the 8 wheels positives, I bet that sunk 6 wheeler had as much to do with the operator as the machine.
Firewoodjoe
Quote from: chevytaHOE5674 on August 27, 2022, 11:23:27 AM
I agree with that. But we don't cut wet ground generally.
Firewoodjoe
Quote from: barbender on August 27, 2022, 10:51:31 AM
Loaded with tracks on the back. In dirt. No ice yet. And I ran my 4 wheeler all winter and never put chains on it in hills. First and only winter that happend though.  A lot has to do with how the job and machines are cut and operated. I do believe an 8 wheeler would be unbeatable with tracks all the way around. I just don't want one I guess.
Skeans1
@Firewoodjoe
It's also going to come down to tire choice for the application the standard forwarder style tires not running tracks don't fair very well when ram bare. That said we've had both over the years and the 6 vs 8 if both are tracked up same operator the 8 will go on steeper ground as well as rougher ground such as holes.
barbender
Joe I can only speak to what I've experienced firsthand, and that is Ponsse Buffalo and BuffaloKing 8 wheels. The standard configuration for us is tracks on the back and one set of chains on the front, and the machines run that way 80-90% of the time. The rest is with no tracks or chains sometimes in the summer. In 11 years I had both ends tracked once, on a soft job. Really wasn't necessary either, but the forester was being really fussy.
 I don't know what the the operations you saw were running for machines or how the operators were doing things, but I can say the machines I ran were rarely wanting for traction. Steep hills they would sometimes spin, but often as not the hydraulic drive would hit the relief pressure. Never have I spun all over pushing a truck, and I've pushed a LOT of trucks...that said, our trucks are #90-100K, your's are #160K? I'm sure that makes a difference😬
Firewoodjoe
Quote from: barbender on August 27, 2022, 01:48:23 PM
They were ponsse Buffalo. And yea our trucks are 159 and 164. Legally that is.  And I'm not saying a 6 wheeler would do better. But I could get away with just chains on the front most times. I'm not winding what I want anyways. Prolly won't. 🤦‍♂️
Firewoodjoe
@barbender how many hours have you sat in a single forwarder before engine or driveline/boggie problems?
barbender
Well, the only machine I sat in exclusively was the '17 BuffaloKing I got new. It had 7500 or so hours when I got out of it. That machine had zero engine or driveline issues, very good👍I've been in and around several other machines, we had one Buffalo that had probably 30K on it when it was finally traded in. I was running it from around 16K to 20K or so. That machine was really reliable engine and driveline-wise too. It was still a productive machine when it was traded. I was in one other BuffaloKing for 4 years or so. That one was probably an '08 or so. It had many engine issues and before I got it, apparently it was on it's 3rd engine at 12K hours😬 It was purchased low hour used from down South somewhere. Apparently someone had messed with the air filter system (or they were just running without one) they had managed to coat the intake system with dirt so it ate a few motors before it was figured out🤦‍♂️I did have a transmission failure in that machine, don't really know what caused it. In fact, it didn't even lay down. It was into Ponsse for routine service and they found bearings in the oil😬 So they replaced it. As far as I can remember, that was the only major component failure I had in 25-30K hours in the seat.
 The Mercedes engines are very good, IMO. I'm pretty sure if my boss could've figured a way to economically stuff them in Cat, Deere, and Cummins powered equipment he would've.
 I never saw any suspension/bogie issues that weren't caused by operator neglect/inattentiveness. There are big bolts that hold your main axle into the C-frame of the machine. They come from beneath (they thread into the brake cans, I guess) and up through the frame, where they are tightened in place with a large nut. You have to keep those nuts tight, if they get loose, they will break and then there is a cascade effect of things that keep breaking until you have some real issues. All completely preventable.
 One of the nice things about getting a new machine is being directly responsible for everything on it, and being able to see a difference if the machine is treated well. I crawwwwwlllll through the woods- loaded, empty, don't matter. I figure if it's knocking my guys out it's beating the machine to death too! The shock loads generated from slamming off stumps etc. tear stuff up, especially with 5 cords of wood piled on top of the machine. My method was to "load big, drive slow". I was one of the most productive operators, and I didn't break stuff. I've seen that go through the woods so fast that even though the load is a foot beneath the stakes, they still have sticks flying out. Idiot, is all I can say. Make your time with smooth, efficient unloading and not skidding speed. Hope this helps.
barbender
I should clarify, the only bogey issues I ever saw were the busted up mount from operator abuse. The only other bogey issue I saw was also operator abuse- letting chains get so loose they ride over on the tire and cut the bogey axle beam. Not good!
Dom
On the rottne SMV we used to say there wasn't much difference in floatation or traction between the 6WD and 8WD. There was a difference in the ride. A 6wd would go over and feel 1 big bump, the 8wd, 2 small bumps.
The 6wd in winter users would place tracks in the back, chains up front. 8wd tracks all around in winter.
Summertime it depended on the ground, but almost always tracks in the back.
Some would put chains on the frontmost tires instead of tracks for the 8wd. It seemed to work well for summer and winter.
Firewoodjoe
Thanks for the thought out post barbender. Yeah what I see is past 6,000 hours of 3-4 years is all a gamble.
The guys with 8 wheelers I know. won't even buy a new one without tracks.
Ken
My 8 wheel Buffalo has a little better than 11k hours and I run tracks on all tires.  Makes for a smooth ride with minimal ground disturbance.  I had a 6 WD Timberjack which was a great machine but certainly rougher on the operator.  I also crawl through the bush slow with my machine.  Easier on the machine and me.
barbender
As I get more seat time in this 6 wheel Ponsse Wisent I'll have more of an opinion on it, no doubt😊
Skeans1
@Firewoodjoe
What is this machine going to be used for mostly thinning or clear cutting?
What are the requirements for compaction or disturbance of the soils?
Firewoodjoe
Quote from: barbender on August 30, 2022, 06:57:43 PM
Really  I was just looking at a used wisent online. Lots of hours but wondering if they hold two bunks of tens. I'm the pic it looked like it did.
Firewoodjoe
Quote from: Skeans1 on August 30, 2022, 07:17:34 PM
@Firewoodjoe
I want it able to do hardwood thinnings. With that being said the jobs I cut the mill has had everything on them. Small to big. We can work most thinnings except row pine. Which I don't really care about. The mill dont but much of that. And boring anyways. Rut restrictions yes but I've never had a problem even with 4 wheelers. Laying brush matt and moving around seems to keep most foresters happy. I want it under 10 foot. And close to 200hp and hold two bunks of tens. That's it. I feel like I want a 6 wheeler. Lots of guys swear by them here. (Deere's) and it's one less boggie in the future. Most jobs I can get away with just chains on the front. No tracks. Guys here do it. But not possible with an 8 wheeler. Tracks are a must. But as usual money and condition is the biggest problem. I want one with low hours but not new price and that's not looking good. So maybe one with some engine and bogie paper work🤷‍♂️ I have time.  I'm not rushing it. I bought this valmet in some what of a rush and it's a good machine. But it's what I expected. I don't feel like I got the improvement I wanted going from a single bunk. It's is dont get me wrong but not enough.
Firewoodjoe
FYI the mill has five 8 wheelers. All ponsse. So I have an idea about them. There good. If tracked up. But also all the dealers are in one town except Deere. And they are closest to me.
barbender
You could move the bunks around to get two rows of 10's on a Wisent, maybe. It would be tight. I've been skidding 9' and 8' with this one and putting the 9' in front.
