Author Topic: Would you Purchase One Again?  (Read 4545 times)
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
« on: December 06, 2014, 09:52:04 PM »
I've been really looking at the Norwood Sawills as my first sawmill. I've been impressed with the components that they use.  If you had to purchase one again, would you?  When you remove your boards from a cant, do they all measure the same thickness?
Have you had many problems with the mill?
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline Glen Sutton
  • So Many Hobbies! So Little Time.
Re: Would you Purchase One Again?
« Reply #1 on: February 03, 2015, 03:48:26 PM »
I bought the LM29 as my first band mill. It really works well for me. I've had no problem with maintaining accuracy of the thickness of boards. Similarly, my timbers turn out straight and true, to the extent that the machine base has been aligned and levelled properly. The Vee twin briggs really rocks. My only complaint is that its too cold to use the saw in january. Best wishes if you do purchase one.
Duncan
Offline jdw
« Reply #2 on: April 02, 2015, 02:18:03 PM »
What kind of production can you get out of yours in a day?
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #3 on: April 02, 2015, 02:41:00 PM »
Asking what kind of production another individual can get out of a given mill is absolutely irrelevant to what you want to know. You will be the ultimate deciding factor in that, depending on your experience, your work ethic and attitude, the amount of help you have, the support equipment you use, the log size and type, the dimensions of the lumber you cut from those logs and on and on and on.  And everyone of those variables will be different for any other individuals situation, making the question perhaps fun to ask, but the information received, irrelevant.
Offline jdw
« Reply #4 on: April 02, 2015, 02:48:24 PM »
Well I feel the question is a good one. All I wonna know is how much production you can get out of the mill in a day. Now norwood says 4000 a day now that sounds a little far fetched to me but possible  under perfect conditions I guess. I just want a basic idea of what the mill can produce.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #5 on: April 02, 2015, 03:01:05 PM »
My reply stands. Do you have prior experience as a sawyer with any mill?
Offline beenthere
« Reply #6 on: April 02, 2015, 03:30:06 PM »
jdw
I notice you had a mill before... think it was a Hud-son ?  What were your daily bdft production totals looking like?
https://forestryforum.com/board/index.php/topic,82402.msg1257078.html#msg1257078
Also, what production do you think you will need to meet your needs (IIRC you are planning to live off the production of the mill).
Offline jdw
« Reply #7 on: April 02, 2015, 03:51:48 PM »
Yes I do several years also have equipment to move logs and 2 off bearers so my question Stands as well how much production is realistic? :o
Offline beenthere
« Reply #8 on: April 02, 2015, 04:04:06 PM »
And your production was what?
Seems that is relevant to your question about others' production, as well as in your planning to get a Norwood mill instead of the Frick circular mill.
Offline jdw
« Reply #9 on: April 02, 2015, 05:14:47 PM »
Ok let me ask like this. You have a yard full of 16 inch 14 foot white oak logs a norwood LM 29 three people working the mill, the temperature  outside is 87 degrees with a 10mph wind coming from the southeast. Your truck has white wall tires and there's 3 cows grazing to your left Oh yea you got a tractor to put logs on the mill. How many bf could you cut a day :D
Offline beenthere
« Reply #10 on: April 02, 2015, 05:19:27 PM »
 :D :D :D
Offline jdw
« Reply #11 on: April 02, 2015, 05:33:50 PM »
All jokes aside I'm just wondering I had a hudson 328 bought new and ran for a few years cut lots of lumber with it but it was slow real slow. That's why I wanted a circle saw I know with the people I got helping me and the addition of a edger we could put out lots of lumber and that's what my goal is. But went and looked at the old frick and it was suppose to be a running mill and wasnt. The mill it's self was in great shape missing a few parts but nothing big. But the diesel power unit seemed kinda rough under normal circumstances  this wouldn't have been an issue I would have bought it went through the motor. But due to getting my walking papers at work and people already wanting lumber I was forced to make a decision  so I can get up cutting asap. But at the same time I read about woodmizer and a few other mills according to what I've read the lm 29 has the best bang for the buck. I'm just asking the question cause I'm hoping not to be in the same boat as I was with the Hudson . :'(
Offline red
  • we will never forget
« Reply #12 on: April 02, 2015, 05:57:17 PM »
If You Ran a Sawmill for Years? . .how many bf a day did you cut?
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Glenn1
    • GPS Hardwoods
« Reply #13 on: April 02, 2015, 06:04:54 PM »
And to think, my original question was "Would you purchase the mill again"    :D :D :D :D
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #14 on: April 02, 2015, 06:10:34 PM »
You would cut nothing as you would still be asking how much you could cut. Like I said, you can ask and get answers, but having been a commercial sawyer for over 25 years, working with hundreds of different people and observing dozens of other sawyers, I know for a fact that the mill, as long as it is in working condition as designed, has very little to with what your eventual production will be.  I'm not trying to be smart, I'm trying to let you know what the reality is. If the manufacturer says 4000 feet, that should be your highest bench mark, not what some other random person may have achieved with unknown variables.
Offline jdw
« Reply #15 on: April 02, 2015, 06:31:01 PM »
Well with the ol under powered hudson you would be lucky at very best I'd say 1500 a day  of course you had to allow time to get it running fix broken stuff the dogs were bad to break bend. I mean this mill was as manual as they come  but in fairness to hudson they did say 200 ft and hour would pretty much be max.I do plan though on getting a edger with this new mill so that should speed up things quite a bit. I guess a better way to word the question would have been. Which produces lumber quicker hudson 328 or norwood LM 29 8) but hey we wouldn't be having this big scientific  conversation  had I went that route  :D
Offline red
« Reply #16 on: April 02, 2015, 06:51:07 PM »
I wonder what your Boss was thinkin as he gave you Those Walkin Papers
Offline Glenn1
    • GPS Hardwoods
« Reply #17 on: April 02, 2015, 07:25:47 PM »
 :D :D :D
Offline jdw
« Reply #18 on: April 02, 2015, 09:23:12 PM »
So let me get this straight your trying to take cheap shots at me but not intelligent  enuff to to answer a simple question about getting production out of a mill? OK then ::)
Offline red
« Reply #19 on: April 02, 2015, 09:35:12 PM »
You really should not have said my truck has white wall tires. . . It was Fair Game from there
But Jeff answered your Question in his. First Sentence
new purchase
Started by bull on General Board
Last post December 22, 2009, 05:36:20 PM
by woodmills1
saw purchase
Started by bitternut on Chainsaws
Last post October 20, 2006, 10:16:41 PM
by logger
New purchase
Started by DOVEMAN on Sawmills and Milling
Last post June 25, 2014, 05:20:21 AM
by xlogger
new purchase
Started by Wallys World on General Board
Last post July 02, 2008, 06:47:53 PM
by Wallys World
