Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later. Any body else been getting this. I been seeing it a lot lately. Ususall have to get out and sign back in.
Also, noticed the gallery was unavailable.
Said:
Coppermine critical error:
Unable to connect to database !
MySQL said: Too many connections
Can't upload or view the images.
yes I'm getting that. Thought it was my puter.
I'm on it. I've got the gallery shut down for the foreseeable future as I think that is the problem, but don't have a solution yet.
Yes, been getting that also for a couple days last week.
I just thought that the FF is such a popular place the broadband could not keep up. :D
I see the pictures are working again. What did you discover as the problem?
I dont know yet. I'm still scrambling on it. It comes and goes. I've rebooted the server a few times and also restarted the database repeatedly to get things running. I'm beginning to think it may be some sort of DOS attack. Something is overwhelming the mysql server with connections. There is a limit, and when that limit is reached, new connections get an error. I've ran table repair scripts and such and still not sure what is going on. I've got a call in to a higher power to see if we can get it figured out. I have other options for help yet to if I need it.
I've made no changes in any of the software or any configurations so I don't know what to think as yet, other then a server issue or an outside influence.
Still no outside help yet, so I did some table repair and rebooted the server. We'll see. Its been pretty bad this afternoon, but so far I have not got any errors since the reboot about 20 minutes ago
You don't recon thr BS bucket overflowed ??
Since I rebuilt the data tables this afternoon, I have not had any personal incidents with the connection. I was seeing it every few clicks before that.
Are you or the company running the server monitoring any of the network traffic? If you are logging all network connections/attempts, it should be pretty easy to determine if the server is being DOS'd.
I turned on the logging today, I dont always have it running as logs can consume lots of space. I'm leaning back towards a troublesome db table as it seems things have cleared up.
Glad to hear it. Drop me a PM if you ever need assistance with net logs and whatnot. I'd be glad to help.
It happened to me once a couple minutes ago.
Quote from: LeeB on August 23, 2009, 05:11:11 PM
I've been getting that once in a while!
I usually just click on the "ahead" arrow and go back to where I was, then hit the "back" arrow again and it works for me, but not so often, I have to exit and come back in!
Happened to me a few minutes ago and again when I tried to post to this thread.
I've not had any trouble the last two days on multiple systems.
Teri, in Fl., and, me down here, are both having trouble with the server busy message. ::) ::)
Connection Problems
Getting it again here right now.
