Author Topic: Sandblasting a Painted Log Home...Anyone tried it?  (Read 989 times)
Offline Stephen1
    • muskoka Sawmill
Re: Sandblasting a Painted Log Home...Anyone tried it?
« Reply #20 on: May 04, 2021, 08:42:58 AM »
hahaha. Vinyl siding. As much as I hate installing Hardie, thats probably the route I would go. The stuff is bullet proof if installed correctly. I have WM LT15, but no trees anymore. I'm hoping to get some logs dropped off. Then I would really be in business. IMHO vinyl siding should be illegal, again, IMHO.  :D
My friend installed Hardie, told it had to be repainted after 10 years, for his 25 year warranty, got a quote to paint for 9K, he ended up putting vinyl siding on for 6K.
Nothing about a log home is inxpensive, especially when it has not been maintained.
Offline kantuckid
« Reply #21 on: May 04, 2021, 02:13:22 PM »
Mine's been maintained and honestly said it was inexpensive. I worked for zilch but I felt good about doing that overall. :D
The Forestry Forum is an "interesting place" to talk up vinyl siding on log homes? I mentioned it as a joke. I stripped a solid stain off my log home using Lowe's Olympic stripper. Then I sanded it with my 5" orbital Makita sander over a couple of weeks. Had to buy an under $10 new velcro disc for it, still use it. As I'd mentioned, I did try some corn cob grit using my portable compressor and a handheld sand blaster which was ineffective. That blaster is one I had for AB work with a stationary compressor. The logistics were poor to rent a cob blaster so I did what I could afford that gave a good result. Never did vinyl siding enter my mind.
Few years back I read a local news article on vinyl siding. This journalist had hit something with a riding mower that had flown and busted some of her homes vinyl siding. She was amazed to learn that it was nearly a $1,000 repair to color match the siding for a small area of damage.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #22 on: May 05, 2021, 10:08:26 AM »
When I first started using Hardie, I ran into issues all the time. Being in a high fire danger area, it is more common than not to use Hardie. I believe that they have their manufacturing process down now, and if you follow their recommendations (which can be hard and expensive to do) you end up with a strong product that can last a lifetime.
We have a huge pine beetle problem here in the west and thus, millions of trees are being cut down. I'll send some photos when I can. I have a connection with someone to get these trees to my property so I will probably use them to fix the aesthetic issue of the painted logs. I'm more of a carpenter, not a sander. Not saying I cant sand...I just don't want to.
Vinyl siding isn't used out here very much. In my experience, it's rare to see it. In the few instances that I have seen it it's been when a client wants it all gone so they can sell their house, because "no one wants to buy a house with vinyl siding." Not trying to sound like a brat but that's just my experience. The process of making it and the act of sending it all to the dump hurts the soul. My opinion.
Offline kantuckid
« Reply #23 on: May 06, 2021, 10:21:48 AM »
Over in Denver, Boulder, CS's,  etc. there's probably plenty of that plastic stuff. I hear you on the dump thing. As I've played devils advocate you've taken it nicely, thanks!  ;D I'm not real keen on sanding either (paint stripping is even worse) but I do what I gotta do sometimes...
Online metalspinner
Online btulloh
« Reply #25 on: May 08, 2021, 08:13:13 AM »
Cool tool.
HM126
Offline flyingparks
« Reply #26 on: May 08, 2021, 07:22:42 PM »
could work nicely
sandblasting 353
Started by sandersen on Forestry and Logging
Last post September 22, 2015, 09:47:13 PM
by ga jones
sandblasting
Started by bedway on General Board
Last post September 19, 2016, 07:03:50 AM
by MikeON
Sandblasting?
Started by Woodhauler on General Board
Last post May 08, 2017, 06:02:21 PM
by Woodhauler
Sandblasting
Started by westyswoods on General Board
Last post February 18, 2012, 06:46:12 AM
by westyswoods
