Author Topic: Cat D4C II track adjuster seal replacement  (Read 618 times)
Online LeeB
« on: April 21, 2021, 03:35:07 PM »
Seals are shot on my dozer track adjuster. Anyone changed them on this model before? Sure could use some pointers here.
Online LeeB
Re: Cat D4C II track adjuster seal replacement
« Reply #1 on: April 22, 2021, 08:36:35 AM »
Figured out you have to split the track to have enough room to remove the yoke.
Offline hedgerow
« Reply #2 on: April 22, 2021, 09:16:55 AM »
I have had to do both sides on my 941B Cat track loader and had to split the track to get enough room to remove the yoke and get the piston out to remove the seals. My old Cat isn't too bad to spit the track as it has aftermarket rails and they bolt together.
Online LeeB
« Reply #3 on: April 22, 2021, 09:30:16 AM »
I'm hoping that this one has a master link also. I don't want to have to beat a pin out.
Offline Southside
    • White Oak Meadows
« Reply #4 on: April 22, 2021, 10:44:53 AM »
Don't you have a mud hole you can just drive into and turn sharp? Guarantee that the track will remove itself that way.
The rest is up to you to figure out.  :D
Offline PoginyHill
  • Gentleman logger
« Reply #5 on: April 22, 2021, 01:58:33 PM »
If your track has worn enough, you might be able to remove it without breaking it by collapsing the idler as far as it can go. I was able to remove my Cat excavator tracks that way when I replaced my final drives.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Online LeeB
« Reply #6 on: April 22, 2021, 03:06:30 PM »
Now I can't get it to start.  >:(
Offline hedgerow
« Reply #7 on: April 22, 2021, 03:34:12 PM »
I know how you feel those old Cat's can be a pain some days. But there are so many things my old track loader will do that my 100 HP skid load will look at and cry. I would be lost with out my old track loader out hear on the farm.
Online LeeB
« Reply #8 on: April 22, 2021, 08:37:46 PM »
Kept acting like it was out of fuel but there was fuel in the tank. It was out of fuel though. Couldn't get past the hole in the fuel line. Once I finally figured that out, got the line fixed, and primed the engine it grudgingly decided to fire up. Was too late to start busting the track by that time. Will try to get it done tomorrow before it starts raining. Lindy wants me to pay somebody to do it but I want to save that $300.
Offline dogone
  • Just beginning and lots to learn
« Reply #9 on: April 22, 2021, 08:59:04 PM »
    May not be applicable but: I had a cat d7e. Removed tensioner attachment bolts.  Chained up front idler and pulled forward with tractor. Had just enough room to get ram out. Helps to have a few strong helpers.
Online LeeB
« Reply #10 on: April 22, 2021, 10:30:44 PM »
Tried that. Not enough room.
Offline Fredholtby
« Reply #11 on: April 23, 2021, 06:52:00 AM »
Hi Iím a cat tech in Ontario Canada
Unfortunatly youíll need to split the track on the bright side you can clean up the wear plates and replace if needed
Not sure what service techs are like in your area
Up here when I use to run a service truck would help out small guys bill you an hour or some times half hour pending time and stop in split track and reconnect at later date
Depends on your time line
Again that was me not sure there but never hurts to call if you need to press it out
Online LeeB
« Reply #12 on: April 23, 2021, 08:56:34 AM »
Thanks Fred. This track has a master link. Luckily, no pin to press out as long as the bolts will break and not snap off.
Offline Fredholtby
« Reply #13 on: April 23, 2021, 09:36:52 PM »
Lee if they break do not heat youíll never get them out
Drill them if they break
Give the heads of the bolts some real good smacks with a sledge to jar them before trying to loosen
Online LeeB
« Reply #14 on: April 23, 2021, 11:53:55 PM »
They broke with no problem. Seals are changed and the track is back together. Now that the seals hold the grease zirk decided to give up. Will need to change it and back out a few of the bolts for the guard that broke off. All in all, I feel pretty good about having tackled this and coming out on top.
Online LeeB
« Reply #15 on: April 29, 2021, 07:11:58 PM »
Got the fuel hose changed out again for the proper one and installed the grease valve for the track adjuster. Started on changing out the shoe pads. Going to need this thing working to fix my drive after 6" of rain yesterday.
Online LeeB
« Reply #16 on: April 30, 2021, 06:58:33 PM »
And now the right side angle cylinder blew it's seals. Old iron is so much fun.
Online LeeB
« Reply #17 on: May 01, 2021, 03:48:37 PM »
Angle cylinder repacked. What next?
Track Adjuster on a Case 450
Started by Qweaver on General Board
Last post April 30, 2007, 11:24:05 PM
by scsmith42
Detroit 453 oil seal replacement
Started by Spartan on Forestry and Logging
Last post February 12, 2017, 10:58:07 AM
by Spartan
440b front axle seal and berring replacement
Started by Jsweet440b on Forestry and Logging
Last post July 20, 2018, 06:13:42 PM
by snowstorm
Mod MS170 to bar side adjuster
Started by rick carpenter on Chainsaws
Last post February 28, 2016, 06:24:29 PM
by rick carpenter
